path: root/board/eNET
2009-09-04Add PCI support to eNET boardGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-09-04i386: Moved PCI from #ifdef to conditional compile for sc520 boardsGraeme Russ
2009-09-04i386: Replace [read, write]_mmcr_[byte, word, long] with memory mapped structureGraeme Russ
2009-09-04i386: Change inline asm global symbols to localGraeme Russ
gcc 4.3.2 optimiser creates multiple copies of inline asm (who knows why) Remove use of global names for labels to prevent 'symbol already defined' errors Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Renamed cpu/i386/reset.S to resetvec.SGraeme Russ
Brings i386 in line with other CPUs with a reset vector and frees up reset.c for CPU reset functions Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Added initial eNET board supportGraeme Russ
