path: root/board/eNET
2010-05-06eNET: Implement eNET WatchdogGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-05-06eNET: Add PC/AT compatibility setup functionGraeme Russ
The eNET uses the sc520 software timers rather than the PC/AT clones Set all interrupts and timers up to be PC/AT compatible Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-05-06eNET: Add support for onboard RTL8100B (RTL8139) chipsGraeme Russ
2010-05-06sc520: Board Specific PCI InitGraeme Russ
2010-05-06x86: Use CONFIG_SERIAL_MULTIGraeme Russ
2010-05-06x86: Add RAM bootstrap functionalityGraeme Russ
Add a parameter to the 32-bit entry to indicate if entry is from Real Mode or not. If entry is from Real Mode, execute the destructive 'sizer' routine to determine memory size as we are booting cold and running in Flash. If not entering from Real Mode, we are executing a U-Boot image from RAM and therefore the memory size is already known (and running 'sizer' will destroy the running image) There are now two 32-bit entry points. The first is the 'in RAM' entry point which exists at the start of the U-Boot binary image. As such, you can load u-boot.bin in RAM and jump directly to the load address without needing to calculate any offsets. The second entry point is used by the real-to-protected mode switch This patch also changes TEXT_BASE to 0x6000000 (in RAM). You can load the resulting image at 0x6000000 and simple go 0x6000000 from the u-boot prompt Hopefully a later patch will completely elliminate any dependency on TEXT_BASE like a relocatable linux kernel (perfect world) Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-05-06x86: Fix MMCR AccessGraeme Russ
Change sc520 MMCR Access to use memory accessor functions Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-04-13Change directory-specific CFLAGS to use full pathPeter Tyser
Previously, a specific file or directory could be compiled with custom CFLAGS by adding a Makefile variable such as: CFLAGS_dlmalloc.o = <custom flags for common/dlmalloc.c> or CFLAGS_lib = <custom flags for lib directory> This method breaks down once multiple files or directories share the same path. Eg FLAGS_fileA = <custom flags> would incorrectly result in both dir1/fileA.c and dir2/fileA.c being compiled with <custom flags>. This change allows finer grained control which we need once we move lib_$ARCH to arch/$ARCH/lib/ and lib_generic/ to lib/. Without this change all lib/ directories would share the same custom CFLAGS. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-05i386: Final RelocationGraeme Russ
2009-12-05i386: Remove inline asm symbols from .dynsymGraeme Russ
2009-12-05i386: Fix link collisions resulting from gcc4.4.1 upgradeGraeme Russ
2009-12-05i386: Fix dlmalloc compile warningGraeme Russ
2009-09-04Add PCI support to eNET boardGraeme Russ
2009-09-04i386: Moved PCI from #ifdef to conditional compile for sc520 boardsGraeme Russ
2009-09-04i386: Replace [read, write]_mmcr_[byte, word, long] with memory mapped structureGraeme Russ
2009-09-04i386: Change inline asm global symbols to localGraeme Russ
gcc 4.3.2 optimiser creates multiple copies of inline asm (who knows why) Remove use of global names for labels to prevent 'symbol already defined' errors Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Renamed cpu/i386/reset.S to resetvec.SGraeme Russ
Brings i386 in line with other CPUs with a reset vector and frees up reset.c for CPU reset functions Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Added initial eNET board supportGraeme Russ
