path: root/board/eNET/config.mk
2011-04-13eNET: Remove config.mkGraeme Russ
By including <config.h> in the ld script, CONFIG_SYS_MONITOR_LEN (defined in the boards config file) can be used in lieu of FLASH_SIZE (defined in the board specific config.mk) As this is the last remaining entry in the board specific config.mk, this file can now be removed Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-02-12x86: Parametize values used in linker scriptGraeme Russ
2011-02-12eNET: Create distinct board configurationsGraeme Russ
Position independant functionality is due for removal from the x86 architecture, so create two distinct configurations - One for Flash and one for SRAM
2011-02-12x86: Align config.mk and linker scripts with other archesGraeme Russ
2010-05-06x86: Add RAM bootstrap functionalityGraeme Russ
Add a parameter to the 32-bit entry to indicate if entry is from Real Mode or not. If entry is from Real Mode, execute the destructive 'sizer' routine to determine memory size as we are booting cold and running in Flash. If not entering from Real Mode, we are executing a U-Boot image from RAM and therefore the memory size is already known (and running 'sizer' will destroy the running image) There are now two 32-bit entry points. The first is the 'in RAM' entry point which exists at the start of the U-Boot binary image. As such, you can load u-boot.bin in RAM and jump directly to the load address without needing to calculate any offsets. The second entry point is used by the real-to-protected mode switch This patch also changes TEXT_BASE to 0x6000000 (in RAM). You can load the resulting image at 0x6000000 and simple go 0x6000000 from the u-boot prompt Hopefully a later patch will completely elliminate any dependency on TEXT_BASE like a relocatable linux kernel (perfect world) Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-04-13Change directory-specific CFLAGS to use full pathPeter Tyser
Previously, a specific file or directory could be compiled with custom CFLAGS by adding a Makefile variable such as: CFLAGS_dlmalloc.o = <custom flags for common/dlmalloc.c> or CFLAGS_lib = <custom flags for lib directory> This method breaks down once multiple files or directories share the same path. Eg FLAGS_fileA = <custom flags> would incorrectly result in both dir1/fileA.c and dir2/fileA.c being compiled with <custom flags>. This change allows finer grained control which we need once we move lib_$ARCH to arch/$ARCH/lib/ and lib_generic/ to lib/. Without this change all lib/ directories would share the same custom CFLAGS. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-05i386: Final RelocationGraeme Russ
2009-12-05i386: Fix link collisions resulting from gcc4.4.1 upgradeGraeme Russ
2009-12-05i386: Fix dlmalloc compile warningGraeme Russ
2009-01-24Added initial eNET board supportGraeme Russ
