Preperation for conditional DDR3 initialization based on GPIO codes.
Signed-off-by: Ludwig Zenz <lzenz@dh-electronics.de>
This reverts commit a637fe6f27fd4c19ef9f43a5f871c244581422ac.
The DDR DRAM calibration was enhanced by write leveling correction code.
It can be used with T-topology now.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
In order that we can use eth_env_* even when CONFIG_NET isn't set, move
these functions to environment code from net code.
This fixes failures such as:
board/ti/am335x/built-in.o: In function `board_late_init':
board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr'
u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr'
which caters for use cases such as:
commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment
variable")
when Ethernet is required in Linux, but not U-Boot.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
The DDR DRAM calibration doesn't work on T-topology sometimes, so disable it.
The board uses T-topology for the four x16 DRAM chips, so remove
the write-leveling from the SPL as that is only usefly on fly-by
topology and can be harmful on T-topology. Also update the DRAM
timing with values from calibration on multiple boards.
As part of my usual round of build testing, output about missing
MAINTAINERS information was not logged, and thus often overlooked.
Correct that mistake by ensuring that I log the output of
genboardscfg.py every time. As part of that, address a number of
missing MAINTAINERS entires. In the case of a missing file, I have put
the original submitter down. In the rest of the cases I have added the
config (and sometimes relevant header file) to the existing set of file
globs.
Enable UMS and DFU, so that the eMMC can be accessed via the
USB gadget port on the board.
Add support for the DHCOM i.MX6 PDK board. This board has:
- FEC ethernet
- EHCI USB host
- 3x SDMMC
