The DHSOM uses different SPI NOR layout than the ST devkit, stop
pulling in the ST specific runtime mtdparts settings and adjust
the mtdparts accordingly.
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Add a function stmpic_init to early initialize the PMIC STPMIC1
- keep vdd on during the reset cycle (to avoid issue when backup battery
is absent)
- Check if debug is enabled to program PMIC according to the bit
This patch allows to remove the compilation of spl.c file from stm32mp1
board in dh_stm32mp1.
CONFIG_SPL_BOARD_INIT is removed as the new function is called earlier
in SPL, in the function board_early_init_f.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Move function board_ddr_power_init() in a new file stpmic1 in
board/st/common to avoid duplicated code in each board using
stpmic1
Move the stm32mp1 common code set_dfu_alt_info() in common directory,
this patch reduce the maintenance effort on this generic part (not board
dependent).
Move the stm32mp1 common code board_get_mtdparts() in common directory,
dependent).
Add support for DH Electronics DHCOM SoM and PDK2 rev. 400 carrier
board. This is an SoM with STM32MP15xx and an evaluation kit. The
baseboard provides Ethernet, UART, USB, CAN and optional display.
Cc: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
