path: root/board/dfi
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-06-17x86: baytrail: Drop EFI-specific test logicsBin Meng
Now that we have generic EFI payload support, drop EFI-specific test logics in BayTrail Kconfig and codes, and all BayTrail boards too. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-24x86: dfi-bt700: Select SERIAL_RX_BUFFER via KconfigStefan Roese
To support more input characters (longer stings pasted into the U-Boot prompt) without dropping, lets selects the recently added UART RX buffer for these boards. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-08x86: dfi: Add option to select different config headers for baseboardsStefan Roese
This patch adds the infrastructure to define different config headers with different configurations and default environment for the baseboards that can now be selected via Kconfig. The new configuration for the theadorable-x86-dfi-bt700 is also added. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-01x86: kconfig: Let board select SPI flashBin Meng
Only a specific type of SPI flash exists on a board, having board Kconfig to select the SPI flash seems to make more sense. Other flash types are not necessary except coreboot, which implies all available flash drivers there. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Let board select BOARD_EARLY_INIT_FBin Meng
CONFIG_BOARD_EARLY_INIT_F literally indicates board-specific codes and should be not 'default y' for all x86 boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-30x86: dfi-bt700: Add xHCI USB supportStefan Roese
Change from EHCI to xHCI on the DFI BayTrail SoM. The xHCI USB hub is connected to an GPIO on the DFI BayTrail SoM. For correct operation, it needs to get reset upon power-up. Otherwise it may happen that the hub is not detected after a software reboot. This patch also configures this GPIO in the dts for correct operation. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: Add theadorable-x86-dfi-bt700 board supportStefan Roese
This patch adds support for the BayTrail based theadorable-x86-dfi-bt700 board which uses the DFI BT700 BayTrail Qseven SoM on a custom baseboard. The main difference to the DFI baseboard is, that it isn't equipped with a Super IO chip and uses the internal HS SIO UART (memory mapped PCI based) as the console UART. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: Add DFI BT700 BayTrail board supportStefan Roese
This patch adds support for the DFI BayTrail BT700 QSeven SoM installed on the DFI Q7X-151 baseboard. The baseboard is equipped with the Nuvoton NCT6102D Super IO chip providing the UART as console. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
