path: root/board/denx/mcvevk
2016-10-27arm: socfpga: mcvevk: Adding handoff for SDRAM ctrlcfg.extratime1Chin Liang See
Adding new handoff for SDRAM ctrcfg.extratime1 which is required for stable LPDDR2 operation. Since the board is using DDR3, the handoff is set to default value 0. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: Drop the board boilerplateMarek Vasut
Drop all the common board code, since it is not completely useless. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: mcvevk: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
This patch adds the necessary OF alias for the UDC node, which let's the code locate the DWC2 UDC base address in OF instead of hard-coding it into the U-Boot binary. The code is adjusted to use the address from OF instead of the hard-coded one. Finally, the hard-coded address is removed and USB DM support is enabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-17usb: s3c-otg: Rename usb/s3c_udc.h to usb/dwc2_udc.hMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch renames the global s3c_udc.h header to dwc2_udc.h. The rename is done automatically: $ sed -i "s/s3c_udc\.h/dwc2_udc.h/g" \ `git grep "s3c_udc\.h" | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-17usb: s3c-otg: Rename s3c_udc_probe() functionMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch is the second and final to rename global symbol, the s3c_udc_probe() function. The rename is done automatically: $ sed -i "s/s3c_udc_probe/dwc2_udc_probe/g" \ `git grep s3c_udc_probe | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-17usb: s3c-otg: Rename struct s3c_plat_otg_dataMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch is the first to rename global symbol, the struct s3c_plat_otg_data. The rename is done automatically: $ sed -i "s/s3c_plat_otg_data/dwc2_plat_otg_data/g" \ `git grep s3c_plat_otg_data | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-09-12arm: socfpga: mcvevk: Update DRAM clock to 400MHzMarek Vasut
The MCV SoM has DDR3-1600 DRAMs on it, update the DRAM speed to 400MHz to make use of these DRAMs completely. Signed-off-by: Marek Vasut <marex@denx.de>
2015-09-04arm: socfpga: Add support for DENX MCV SoM and MCVEVK boardMarek Vasut
Add support for DENX MCV SoM, which is CycloneV based and the associated DENX MCVEVK baseboard. The board can boot from eMMC. Ethernet and USB is supported. Signed-off-by: Marek Vasut <marex@denx.de>
