path: root/board/denx/m53evk/m53evk.c
2014-03-31arm: mx5: Avoid hardcoding memory sizes on M53EVKMarek Vasut
The DRAM size can be easily detected at runtime on i.MX53. Implement such detection on M53EVK and adjust the rest of the macros accordingly to use the detected values. An important thing to note here is that we had to override the function for trimming the effective DRAM address, get_effective_memsize(). That is because the function uses CONFIG_MAX_MEM_MAPPED as the upper bound of the available DRAM and we don't have gd->bd->bi_dram[0].size set up at the time the function is called, thus we cannot put this into the macro CONFIG_MAX_MEM_MAPPED . Instead, we use custom override where we use the size of the first DRAM block which we just detected. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2013-12-17ARM: mx53: video: Add IPUv3 LCD support for M53EVKMarek Vasut
This patch adds support for the AMPIRE 800x480 LCD panel that is available for M53EVK. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2013-05-05imx: m53evk: Convert to iomux-v3Benoît Thébaudeau
There is no change of behavior, except for the folloing line that has been removed because the iomux mode was not set accordingly and the pad used for OTG OC is not this one: mxc_iomux_set_input(MX53_USBOH3_IPP_IND_OTG_OC_SELECT_INPUT, 1); Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-05-05arm: mx5: Add support for DENX M53EVKMarek Vasut
Add basic support for the DENX M53EVK board. Currently supported is: MMC (incl. booting) NAND (incl. booting) Ethernet, I2C, USB, SATA, RTC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de>
