path: root/board/denx/m28evk/Makefile
2012-01-16m28evk: Remove 'all' target from MakefileFabio Estevam
Remove 'all' target from Makefile, as this is unused code. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-12-09i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28Marek Vasut
This moves SPL to common location so it can be reused by multiple boards. Also, this commit adjusts M28 SoM to avoid breakage due to the move. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-11-11M28: Add memory detection into SPLMarek Vasut
This code allows the DDR DRAM size to be detected at runtime. The RAM size is stored into two scratch registers, from which it is then fetched in U-Boot. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-11M28: Add MMC SPLMarek Vasut
This patch adds SPL code for the M28 board. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-11iMX28: Add support for DENX M28EVK boardMarek Vasut
This contains support for the following components: - DUART - MMC - Both FEC interfaces - NAND - I2C (RTC, EEPROM) - SPI (FLASH) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
