path: root/board/delta
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-27{delta,zylonite}/lowlevel_init.S: fix typoWolfgang Denk
Commit 9d803d8c mistakenly changed some constants from 0x300 into 300 - this patch fixes it. Pointed out by Tom Evans <tom@ceos.com.au>, see http://article.gmane.org/gmane.comp.boot-loaders.u-boot/51992 for details. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-11-02Consolidate MAX/MIN definitionsAndy Fleming
There were several, now there is one (two if you count the lower-case versions). Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-09-10delta, zylonite: Update nand_oobinfo to nand_ecclayout.Scott Wood
This is part of the switch to newer upstream MTD code. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-07-09board/[d-e]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-03-23Merge with git://www.denx.de/git/u-boot.git#testing-USBMarkus Klotzbuecher
2006-12-21Added support for the TQM8272 board from TQHeiko Schocher
2006-11-27Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-05-23More cleanup for the delta board and the generic usb_ohci driver. AddedMarkus Klotzbuecher
CFG_USB_BOARD_INIT and CFG_USB_CPU_INIT for enabling board and cpu specific initialization and cleanup hooks respectively.
2006-05-22This patch adds USB storage support for the delta board. This is the firstMarkus Klotzbuecher
board to make use of a generic OHCI driver, that calls hooks for board dependant initialization.
2006-04-25delta board: support for magic key detection and handling.Markus Klotzbuecher
2006-04-12Merge with /home/m8/git/u-bootWolfgang Denk
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-04-01* Add support for ymodem protocol downloadWolfgang Denk
Patch by Stefano Babic, 29 Mar 2006 * Memory Map Update for Delta board: U-Boot is at 0x80000000-0x84000000 Merge with /home/mk/8-benq/u-boot
2006-03-30delta board: one more DA9030 fix.Markus Klotzbuecher
2006-03-29Change delta board memory map to start at 0x80000000.Markus Klotzbuecher
2006-03-29delta board: minor update to DA9030 code.Markus Klotzbuecher
2006-03-27delta board: fix DA9030 reset procedure.Markus Klotzbuecher
2006-03-24Merge with http://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2006-03-24delta board: DA9030 initialization and i2c support. Some minor changes toMarkus Klotzbuecher
make the pxa i2c driver work with the monahans cpu.
2006-03-20Cleanup of the monahans cpu and delta board port.Markus Klotzbuecher
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-06Merge with /home/wd/git/u-boot/masterWolfgang Denk
Code cleanup.
2006-03-06Cleanup of NAND support of delta board using the Monahans Data FlashMarkus Klotzbücher
Controller.
2006-03-06NAND finally working. Two bugs fixed:Markus Klotzbücher
* For READ_STATUS and READID commands always 8 bytes need to be read from NDDB. Otherwise they stay there and get send to flash as the first data word when writing. * In nand_base.c the oob variable is not reset so this->oob_buf is overwritten what eventually screws up the bad block descriptor table.
2006-03-04Lots of new stuff:Markus Klotzbücher
* Debug message can be turned on and off. * Waiting for events now times out. * Implemented RESET command. * Added appropriate nand_bbt_descriptor and nand_oobinfo. Remaining Problems: * Read Status still behaves weird an returns invalid stuff sometimes. * ECC Placement does not respect our scheme in nand_oobinfo.
2006-03-03Erasing works too now. The CS don't care causes problem with READSTATUS,Markus Klotzbücher
don't ask me why. There are still bugs in the bad block logic.
2006-03-03Write operation is working. Turned out that the READSTATUS hack was wrongMarkus Klotzbücher
after all.
2006-03-03Writing is working, but there's still a bug that causes the data written toMarkus Klotzbücher
start at an offset of 4 bytes from the start of the page.
2006-03-03Implemented writing, not working yet.Markus Klotzbücher
2006-03-02Moved the waiting loop for "Read Data Request" RDDREQ into theMarkus Klotzbücher
delta_cmdfunc function, because this bit is only set once after a command is sent and this allows read functions to be called multiple times.
2006-03-02Read bug fixed. Now "nand bad" list the badblocks correctly (i hope, sinceMarkus Klotzbücher
there are 0)
2006-03-01Further NAND stuff implemented. Basic read commands seem to work.Markus Klotzbücher
2006-02-28Added GPIO initialization of DF signal. Still not working.Markus Klotzbücher
2006-02-28First steps implementing NAND support. Not working, fails to read ID.Markus Klotzbücher
2006-02-22SDRAM now working.Markus Klotzbücher
2006-02-22SDRAM now working for delta board, but there are still aliasing problems,Markus Klotzbücher
we only see 64MB.
