path: root/board/delta/nand.c
2007-07-09board/[d-e]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-12-21Added support for the TQM8272 board from TQHeiko Schocher
2006-04-12Merge with /home/m8/git/u-bootWolfgang Denk
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-24Merge with http://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2006-03-20Cleanup of the monahans cpu and delta board port.Markus Klotzbuecher
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-06Merge with /home/wd/git/u-boot/masterWolfgang Denk
Code cleanup.
2006-03-06Cleanup of NAND support of delta board using the Monahans Data FlashMarkus Klotzbücher
Controller.
2006-03-06NAND finally working. Two bugs fixed:Markus Klotzbücher
* For READ_STATUS and READID commands always 8 bytes need to be read from NDDB. Otherwise they stay there and get send to flash as the first data word when writing. * In nand_base.c the oob variable is not reset so this->oob_buf is overwritten what eventually screws up the bad block descriptor table.
2006-03-04Lots of new stuff:Markus Klotzbücher
* Debug message can be turned on and off. * Waiting for events now times out. * Implemented RESET command. * Added appropriate nand_bbt_descriptor and nand_oobinfo. Remaining Problems: * Read Status still behaves weird an returns invalid stuff sometimes. * ECC Placement does not respect our scheme in nand_oobinfo.
2006-03-03Erasing works too now. The CS don't care causes problem with READSTATUS,Markus Klotzbücher
don't ask me why. There are still bugs in the bad block logic.
2006-03-03Write operation is working. Turned out that the READSTATUS hack was wrongMarkus Klotzbücher
after all.
2006-03-03Writing is working, but there's still a bug that causes the data written toMarkus Klotzbücher
start at an offset of 4 bytes from the start of the page.
2006-03-03Implemented writing, not working yet.Markus Klotzbücher
2006-03-02Moved the waiting loop for "Read Data Request" RDDREQ into theMarkus Klotzbücher
delta_cmdfunc function, because this bit is only set once after a command is sent and this allows read functions to be called multiple times.
2006-03-02Read bug fixed. Now "nand bad" list the badblocks correctly (i hope, sinceMarkus Klotzbücher
there are 0)
2006-03-01Further NAND stuff implemented. Basic read commands seem to work.Markus Klotzbücher
2006-02-28Added GPIO initialization of DF signal. Still not working.Markus Klotzbücher
2006-02-28First steps implementing NAND support. Not working, fails to read ID.Markus Klotzbücher
