path: root/board/delta/delta.c
2006-04-25delta board: support for magic key detection and handling.Markus Klotzbuecher
2006-04-01* Add support for ymodem protocol downloadWolfgang Denk
Patch by Stefano Babic, 29 Mar 2006 * Memory Map Update for Delta board: U-Boot is at 0x80000000-0x84000000 Merge with /home/mk/8-benq/u-boot
2006-03-30delta board: one more DA9030 fix.Markus Klotzbuecher
2006-03-29delta board: minor update to DA9030 code.Markus Klotzbuecher
2006-03-27delta board: fix DA9030 reset procedure.Markus Klotzbuecher
2006-03-24delta board: DA9030 initialization and i2c support. Some minor changes toMarkus Klotzbuecher
make the pxa i2c driver work with the monahans cpu.
2006-02-28First steps implementing NAND support. Not working, fails to read ID.Markus Klotzbücher
2006-02-20New board directory and config for the benq delta board (copied fromMarkus Klotzbücher
zylonite). Minor pxa-regs.h update.
