path: root/board/dbau1x00
2007-11-17[MIPS] u-boot.lds: Cleanup __u_boot_cmd_{start,end}Shinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-17Fixed mips_io_port_base build errors.Jean-Christophe PLAGNIOL-VILLARD
This patch has been sent on: - 29 Sep 2007 Although mips_io_port_base is currently a part of IDE command, it is quite fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move it to MIPS general part, and introduce `set_io_port_base()' from Linux. This patch is triggered by multiple definition of `mips_io_port_base' build error on gth2 (and tb0229 also needs this fix.) board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-10-21[MIPS] u-boot.lds: Define _gp in a standard mannerShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Fix __got_start and __got_endShinya Kuribayashi
Ensure that __got_start points to top of the `.got', and __got_end points to bottom as well, so that we never fail to count num_got_entries. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Remove duplicated .sdata sectionShinya Kuribayashi
2006-04-11* Fix dbau1x00 BoardHeiko Schocher
- Fix dbau1x00 boards broken by dbau1550 patch PLL:s were not set for boards other than 1550. Flash CFI caused card to hang due to undefined CFG_FLASH_BANKS_LIST. Default boot is now bootp for cards other than 1550. Patch by Thomas Lange Aug 10 2005
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2005-01-22Code cleanup.wdenk
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2004-10-11CleanupLABEL_2004_10_12_0110wdenk
2004-10-11* Enable NAND flash support for NC650 board.wdenk
* Patch by Thomas Lange 07 Oct 2004: Updated README for DBAu1x00 boards to match current status
2004-06-09* Patch by Martin Krause, 27 May 2004:wdenk
Fix a MPC5xxx I2C timing issue in i2c_probe(). * Patch by Leif Lindholm, 27 May 2004: Fix board_init_f() for dbau1x00 board.
2004-01-04* Make BMS2003 use a separate config file to avoid #ifdef mess;wdenk
add I2C support; add support for DS1337 RTC * Add CompactFlash support for BMS2003 board * Add support for status LED on BMS2003 board
2004-01-02* Patch by André Schwarz, 8 Dec 2003:wdenk
fixes for Davicom DM9102A Ethernet Chip (#define CONFIG_TULIP_FIX_DAVICOM): - TX and RX deskriptors must be quad-word aligned - does not work with only one TX deskriptor - standard reset method does not work * Patch by Masami Komiya, 08 Dec 2003: add RTL8139 ethernet driver * Patches by Ed Okerson, 07 Dec 2003: - fix ethernet for the AU1x00 processors in little-endian mode. - extend memsetup.S for the AU1x00 processors in BE and LE modes
2003-12-07* Patches by David Müller, 14 Nov 2003:wdenk
- board/mpl/common/common_util.c * implement support for BZIP2 compressed images * various cleanups (printf -> puts, ...) - board/mpl/common/flash.c * report correct errors to upper layers * check the erase fail and VPP low bits in status reg - board/mpl/vcma9/cmd_vcma9.c - board/mpl/vcma9/flash.c * various cleanups (printf -> puts, ...) - common/cmd_usb.c * fix typo in comment - cpu/arm920t/usb_ohci.c * support for S3C2410 is missing in #if line - drivers/cs8900.c * reinit some registers in case of error (cable missing, ...) - fs/fat/fat.c * support for USB/MMC devices is missing in #if line - include/configs/MIP405.h - include/configs/PIP405.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support - include/configs/VCMA9.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support * enable USB support - lib_arm/armlinux.c * change calling convention of ARM Linux kernel as described on http://www.arm.linux.org.uk/developer/booting.php * Patch by Thomas Lange, 14 Nov 2003: Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to support all these AMD boards. * Patch by Thomas Lange, 14 Nov 2003: Workaround for mips au1x00 physical memory accesses (the au1x00 uses a 36 bit bus internally and cannot access physical memory directly. Use the uncached SDRAM address instead of the physical one.)
2003-10-09* Patch by Steven Scholz, 10 Oct 2003LABEL_2003_10_09_2320wdenk
- Add support for Altera FPGA ACEX1K * Patches by Thomas Lange, 09 Oct 2003: - Endian swap ATA identity for all big endian CPUs, not just PPC - MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize args to linux - add support for dbau1x00 board (MIPS32)
