path: root/board/davinci
2019-12-26board: davinci: Update OMAPL138_LCDK maintainerLokesh Vutla
As per the email discussion[0], add myself as a maintainer to OMAPL138_LCDK and drop Peter's entry. [0] http://u-boot.10912.n7.nabble.com/OMAP-L138-LCDK-giving-up-maintainership-td394211.html Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-12-03board: omapl138_lcdk: add the mmc device to SPLBartosz Golaszewski
We don't have full device-tree support in SPL yet - add an appropriate U_BOOT_DEVICE() to the board file. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-12-03mmc: davinci: drop support for ti,dm6441-mmcBartosz Golaszewski
The DM family of DaVinci SoCs is no longer supported. Drop the irrelevant code from the driver. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-08-20davinci: omapl138-lcdk: Remove empty compiler directivesAdam Ford
There is an #ifdef with nothing inside it any longer. This patch removes this empty #ifdef Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-20ARM: davinci: Remove duplicated referencesAdam Ford
The Kconfig file calls to ti/common/Kconfig twice which makes several of the menu items repeat themselves. In an effort to clean this up, this patch removes the second call which eliminates the duplicate menu items. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-20Revert "ARM: da850-evm: Enable SPI Flash and NAND Flash when booting NOR"Adam Ford
Sorry for the noise, but there appears to be a regression with older hardware. Since it broke the direct_nor boot option, it should be reverted until a better solution is available. This reverts commit 51cd1e2373274dc3167dabba628dcfc25828d36d.
2019-08-12Merge branch '2019-08-11-ti-imports'Tom Rini
- More DaVinci updates and fixes - PCIe support on am65x - Watchdog converted to DM - Assorted other bugfixes
2019-08-12ARM: da850-evm: Enable SPI Flash and NAND Flash when booting NORAdam Ford
Historically there have been various boot options, SPI flash, NAND or NOR. The NOR flash is mutually exclusive with MMC, but it isn't mutually exclusive with NAND or SPI Flash, so this patch enables both NAND flash and SPI Flash when booting from NOR. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-31Revert "ARM: davinci: da850: Manual pinmux only when PINCTRL not available"Adam Ford
This reverts commit 877ab2423bc257045a06bc23d4b9440b82bda6fb. The above patch was designed to shrink code by only pin-muxing items needed for SPL in SPL and relying on driver model or SPL to mux other items. Unfortunately, da850evm_direct_nor doesn't use SPL so items that were only muxed during SPL are not muxed causing the board to no longer boot. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-31ARM: da850-evm: Remove references to CONFIG_DA850_AM18X_EVMAdam Ford
With the removal of da850_am18xxevm, there is at least one whitelisted CONFIG option that can be deleted. This patch removes CONFIG_DA850_AM18X_EVM since it's not required any more Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-29davinci: omapl138-lcdk: enable driver-model in SPLBartosz Golaszewski
Enable CONFIG_SPL_DM and enable the driver model for serial by defining an appropriate device in the board file for da850-lcdk. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-07-29davinci: omapl138-lcdk: remove unneeded includesBartosz Golaszewski
There's no SPI on da850-lcdk. Remove unnecessary includes. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-07-29ARM: da850_am18xxevm: Remove config and referencesAdam Ford
This board has been abandonded for a while. I do not have this hardware and nobody has appeared to notice and/or care that it's orphaned. Since much of this code is inserted into the da850evm code base, removing it from support will make da850evm support easier going forward. This patch removes the da850_am18xxevm_defconfig, README references to this board and the reference to this board from the MAINTAINERS list. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-26ARM: da850-evm: Remove repeated pinmuxing callsAdam Ford
arch_cpu_init() initializes the pinmuxing which is called fairly early in the start sequences, so the board_init function doesn't need to do it again. This patch removes the call from board_init. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-26ARM: da850-evm: Remove duplicate UART initializationAdam Ford
The Low Level init functions start the UART, so it doesn't need to happen during board_init. This patch removes it from board_init. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-25net: davinci_emac: convert to using the driver modelBartosz Golaszewski
Now that we removed all legacy boards selecting TI_EMAC we can completely convert the driver code to using the driver model. This patch also updates all remaining users of davinci_emac. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Tested-by: Adam Ford <aford173@gmail.com> #am3517-evm & da850-evm Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
2019-07-13ARM: davinci: da850: Manual pinmux only when PINCTRL not availableAdam Ford
With a recent update to the pinctrl-single driver and the fact that the da850evm has both DM and OF_CONTROL working in both SPL and U-Boot, some of the manual pinmuxing can be setup to only be activated when either the driver doesn't have DM for it, or when CONFIG_PINMUX isn't available (only during SPL). If the code ever shrinks enough to support PINCTRL in SPL, a lot of this can go away. This also remove some manual pinmuxing not needed by SPL to give SPL a little more breathing room. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-06-05ARM: da850evm: Fix reading MAC from SPIAdam Ford
The MAC address is located at at the last 64K of SPI Flash, and it's 6 bytes long. This patch corrects both the length and starting byte of the MAC address. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-06-05ARM: davinci: omal138_lcdk: fix MMC boot breakage due to driver model conversionSekhar Nori
commit 21af33ed0319 ("ARM: davinci: omapl138_lcdk: Enable DM_MMC") wanted to enable DM_MMC only for U-Boot and not for SPL. But CONFIG_DM_MMC is defined for SPL build too. Because of this MMC device was not getting registered for SPL causing MMC/SD boot breakage. Instead use CONFIG_IS_ENABLED(DM_MMC) which will remain false until CONFIG_SPL_DM_MMC is defined. Tested-by: Adam Ford <aford173@gmail.com> #da850evm Signed-off-by: Sekhar Nori <nsekhar@ti.com> Tested-by: Peter Howard <phoward@gme.net.au> #omapl138_lcdk
2019-05-28ea20: remove boardBartosz Golaszewski
This board still doesn't select CONFIG_DM and seems to be umaintained. As it makes progress on modernizing several DaVinci drivers more difficult and the maintainer has not expressed interest in updating it, this patch proposes to remove it. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Acked-by: Stefano Babic <sbabic@denx.de>
2019-04-23ARM: da850evm: Remove legacy MMC codeAdam Ford
With the migration to DM in SPL and the DT support, the old legacy code is no longer neaded, so this patch removes it Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-12ARM: davinci: da850evm: Enable SPL_OF_CONTROL without PLATDATAAdam Ford
With the memory mapping giving us some more avialable RAM, this updates the da850-evm-u-boot.dtsi to include the serial port, SPI and Flash nodes along with some dependent nodes in the SPL dtb. This also removes the platform data initialization code for the serial port and SPI Flash. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-12davinci: da850evm/omapl138-lcdk: Move BSS to SDRAM because SRAM is fullAdam Ford
In order to fully support SPL_OF_CONTROL, we need BSS to be a bit larger. This patch relocates BSS to SDRAM instead of SRAM which is similar to how ARMv7 boards (like OMAP2+) do it. This means two new variables are required: CONFIG_SPL_BSS_START_ADDR set to DAVINCI_DDR_EMIF_DATA_BASE CONFIG_SPL_BSS_MAX_SIZE is set to 0x1080000 which is 1 byte before the location where U-Boot will load. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-02-19ARM: da8xxevm: Add NAND instructions for da850-evm to READMEAdam Ford
The README.da850 file continues information on how to burn NAND for the LCDK, but not the DA850-EVM. This patch adds both the commands and dip switch instructions for burning and booting NAND. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-01-26linker: Modify linker scripts to be more genericTom Rini
Make use of "IMAGE_MAX_SIZE" and "IMAGE_TEXT_BASE" rather than CONFIG_SPL_MAX_SIZE and CONFIG_SPL_TEXT_BASE. This lets us re-use the same script for both SPL and TPL. Add logic to scripts/Makefile.spl to pass in the right value when preprocessing the script. Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Jagan Teki <jagan@openedev.com> Cc: Maxime Ripard <maxime.ripard@bootlin.com> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: York Sun <york.sun@nxp.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Adam Ford <aford173@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-by: Adam Ford <aford173@gmail.com> #da850evm & omap3_logic_somlv Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-12-11ARM: davinci: Orphan Spectrum Digital AM18xx EVMAdam Ford
I had requested the da850 boards because their previous maintainer had an invalid e-mail address. I work at Logic PD who makes the da850-evm kits, so I have access to various boards of theirs. The Spectrum Digital AM18xx board is based on the Logic PD da850 EVM, but it's not the same company. Since I don't have the hardware to test/verify changes, I would prefer to not be responsible for this board. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-10board: da8xxevm: Add SPL DM for serial, spiJagan Teki
This patch add SPL DM support for da8xxevm boards with SPL serial, SPI drivers supported via platdata. Cc: Adam Ford <aford173@gmail.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Adam Ford <aford173@gmail.com> #da850evm
2018-09-11ARM: davinci: omapl138_lcdk: Enable DM_MMCAdam Ford
With DM_MMC now available, this patch enables DM_MMC for the omapl138_lcdk in U-Boot and keeps the older style for SPL. Signed-off-by: Peter Howard <phoward@gme.net.au> Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: davinci: da850evm: Support DM_MMCAdam Ford
With the updated driver available to support DM_MMC, this patch enables DM_MMC for da850evm. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: configs: Add da850evm_nand to boot from NANDAdam Ford
The DA850-EVM supports booting from NAND when used with the UI expander board. da850evm_nand will create an ais file that can be burned to NAND and booted while storing the env in NAND along with some partitions tables for storing kernel, dtb and rootfs in NAND. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-20ARM: da8xxevm: README: Add NOR booting instructionsAdam Ford
The da850evm with its UI expander board can boot XIP boot from NOR flash. This adds the instructions to the readme. file. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-18dm: gpio: Add DM compatibility to GPIO driver for DavinciAdam Ford
This adds DM_GPIO support for the davinici GPIO driver with DT support. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2017-09-29arm: da850-evm: Enable DM and device tree support for da850-evmAdam Ford
With the device tree ported and DM compatible drivers, enable: OF_CONTROL, DM_SPI, DM_SPI_FLASH and DM_SERIAL Note: DM_SERIAL is not enabled for da850evm_direct_nor_defconfig yet. Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-13ARM: davinci: Update da8xxevm MaintainersAdam Ford
The e-mail addresses for DA8XXEVM BOARD and DA850_AM18XXEVM BOARD are invalid. Remove DA8XXEVM. Update DA850_AM18XXEVM to have me be the maintainer since I work for Logic PD and have access to OMAP-L138 and AM1808 EVM kits. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-13Convert CONFIG_MAC_ADDR_IN_SPIFLASH et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MAC_ADDR_IN_SPIFLASH CONFIG_MAC_ADDR_IN_EEPROM Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-13davinci: da850evm: Make EEPROM MAC code configurableAdam Ford
There was a check for CONFIG_MAC_ADDR_IN_EEPROM and a check for CONFIG_MAC_ADDR_IN_SPIFLASH, however some of the EEPROM related code wasn't encapsulated inside the #if defined statement so the EEPROM code could get executed even when it wasn't explicitly enabled or wanted. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-12davinci: da850-evm: switch to using TI_COMMON_CMD_OPTIONSAdam Ford
Like the OMAP-L138 LCDK before it, let's move the da850-evm and the variations to TI_COMMON_CMD_OPTIONS to cut back one some of the defconfig entries. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-08-16env: Rename eth_getenv_enetaddr() to eth_env_get_enetaddr()Simon Glass
Rename this function for consistency with env_get(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-12davinci: omapl138_lcdk: add support for TI_COMMON_CMD_OPTIONSSekhar Nori
OMAP-L138 LCDK board can benefit from using the commonly used commands enabled by TI_COMMON_CMD_OPTIONS. Source the relevant Kconfig file so TI_COMMON_CMD_OPTIONS can be enabled for OMAP-L138 LCDK board in a future patch. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-20da850: Add instructions to copy AIS image to NANDahaslam@baylibre.com
Add instructions to write an AIS image to NAND by using the u-boot nand tools. Signed-off-by: Axel Haslam <ahaslam@baylibre.com>
2017-02-17da850: Add instructions to copy AIS image to an MMC cardahaslam@baylibre.com
The da850 soc's can boot from a external mmc card, but the AIS image should be written to the correct sector. Add instructions to copy the AIS image to a MMC card. Signed-off-by: Axel Haslam <ahaslam@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
