path: root/board/davinci
2014-02-26arm: make _end compiler-generatedAlbert ARIBAUD
This prevents references to _end from generating absolute relocation records. This change is binary invariant for ARM targets. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-11-17Makefile: rename all libraries to built-in.oMasahiro Yamada
2013-08-18Merge branch 'master' of git://88.191.163.10/u-boot-armTom Rini
Fixup an easy conflict over adding the clk_get prototype and USB_OTG defines for am33xx having moved. Conflicts: arch/arm/include/asm/arch-am33xx/hardware.h Signed-off-by: Tom Rini <trini@ti.com>
2013-08-10video, da8xx-fb: changes for am335x usageHeiko Schocher
to use this driver also on am335x based boards, the following changes are made: - struct lcd_ctrl_config lcd_cfg is now configurable through board code - controller base is configurable through define DA8XX_LCD_CNTL_BASE. To be compatible with older da8xx based boards: If this define is missing, the DAVINCI_LCD_CNTL_BASE is used - Determine LCD IP Version, and make the driver working on lcd revision register values: Version 1: 0x4C100102 Version 2: 0x4F200800 0x4F201000 Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com>
2013-08-10video, da8xx: move da8xx-fb.h to drivers/videoHeiko Schocher
the da8xx-fb driver works also on am335x boards. So move the da8xx-fb.h file from arch/arm/include/asm/arch-davinci to drivers/video, so this driver can used from am335x based boards. Also add WVGA panel_type. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com>
2013-07-26da850evm: Use clrbits function with correct endianessChristian Riesch
The current code uses clrbits_be32 which is incorrect since we are on a little endian machine here. This patch fixes this issue and also removes some unnecessary code: Reading the current GPIO bank state is not required if we are using the SET and CLEAR GPIO registers for setting/clearing bits. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Cc: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
2013-06-21remove all references to .dynsymAlbert ARIBAUD
Discard all .dynsym sections from linker scripts Remove all __dynsym_start definitions from linker scripts Remove all __dynsym_start references from the codebase Note: this touches include/asm-generic/sections.h, which is not ARM-specific, but actual uses of __dynsym_start are only in ARM, so this patch can safely go through the ARM repository. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-10arm: da830: moved pinmux configurations to the arch treeVishwanathrao Badarkhe, Manish
Move pinmux configurations for the DA830 SoCs from board file to the arch tree so that it can be used for all da830 based devices. Also, avoids duplicate pinmuxing in case of NAND. Signed-off-by: Vishwanathrao Badarkhe, Manish <manishv.b@ti.com> Reviewed-by: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2013-06-10da830: add MMC supportVishwanathrao Badarkhe, Manish
Add MMC support for da830 boards in order to perform mmc operations(read,write and erase). Signed-off-by: Vishwanathrao Badarkhe, Manish <manishv.b@ti.com>
2013-04-14da850evm, da850_am18xxevm: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
This target wants to check full SPL size, BSS included. Remove CONFIG_SPL_MAX_SIZE definition and instead define CONFIG_SPL_MAX_FOOTPRINT. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-04-12arm: Make all linker scripts compatible with per-symbol sectionsBenoît Thébaudeau
Let all ARM linker scripts handle properly -ffunction-sections and -fdata-sections. This will be useful for future changes in order to create symbol-specific sections in common .S files. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: relocate_code(): Use __image_copy_end for end of relocationBenoît Thébaudeau
Use __image_copy_end instead of __bss_start for the end of the image to relocate. This is the same as commit 033ca72, but applied to all ARM start.S. This is a more appropriate symbol naming for an image copy & relocate feature, and this also saves a useless copy of data put between __image_copy_end and __bss_start in linker scripts (e.g. relocation information, or MMU initialization tables used only before jumping to the relocated image). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Remove linker lists (LGAs) from SPL linker scriptsAlbert ARIBAUD
Many SPL linker scripts needlessly include linker lists (aka LGAs). Remove them whenever possible; keep it only in the seven am335x_evm variants (am335x_evm, am335x_evm_uart[1-5], am335x_evm_spiboot), where there is actual content in output section .u_boot_list. This commit keeps all u-boot.bin and u-boot-spl.bin in ARM targets byte-identical. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-01davinci: ea20: the console is always set to the serial lineBastian Ruppert
Do not allow to overwrite it when video is enabled. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-10-01davinci: ea20: reorganisation LCD startupBastian Ruppert
2012-09-27da850: Add README.da850Tom Rini
This file documents when to build for da850evm and when to build for da850_am18xxevm. It also documents how to write the u-boot.ais file to persistent storage (such as SPI), in some cases as well as how to write a recovery image. Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Prabhakar Lad <prabhakar.lad@ti.com>
2012-09-01da8xx/hawkboard: Add support for ohci host controllerSughosh Ganu
Also enable the ohci port on hawkboard. These additions result in an increased u-boot size -- adjust the same accordingly in the board's config. Move the usb header for da8xx platforms under arch-davinci. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
2012-09-01da850/omap-l138: Fix NAND flash timingsLad, Prabhakar
Though Commit id a3f88293ddd13facd734769c1664d35ab4ed681f (da850evm: setup the NAND flash timings) has configured the AEMIF timings, they are not exactly in sync with the timings used in Linux. Linux is configuring the timing register as 0x08222204, where as currently it configured to 0x00100084 in U-Boot. This issue was found out when support for NAND SPL is added in U-Boot. Without this patch U-Boot does not come up with SPL. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: modifications for Logic PD Rev.3 AM18xx EVMRajashekhara, Sudhakar
AHCLKR/UART1_RTS/GP0[11] pin needs to be configured for MMC and NOR to work on DA850/OMAP-L138 Rev.3 EVM. When GP0[11] is low, the SD0 interface will not work, but NOR flash will. When GP0[11] is high, SD0 will work but NOR flash will not. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01da850/omap-l138: Add MMC support for DA850/OMAP-L138Lad, Prabhakar
This patch adds support for MMC/SD on DA850/OMAP-L138. Tested-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
2012-09-01hawkboard/omapl-138: Add support for generating ais image for hawkboardSughosh Ganu
Parameters used for configuring certain SoC peripherals are parsed from the cfg file and appended as part of the ais image's header. The u-boot-spl.ais generated is flashed separately to the nand, so do not delete the file after generation of u-boot.ais. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-05-15arm: ea20: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INITNobuhiro Iwamatsu
With almost all the architecture and board BOARD_LATE_INIT does not use. CONFIG_BOARD_LATE_INIT is used instead. This changed CONFIG_BOARD_LATE_INIT from BOARD_LATE_INIT. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-03-27Davinci: ea20: use gpio framework to access gpiosStefano Babic
Drop direct access to SOC's registers and use the function of the GPIO driver for da8xx. [Tom: Remove gpio[68]_base as it's now unused] Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: dzu@denx.de CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-02-27dm6467Tevm: Use a common configuration file for davinci_dm6467evm and ↵prabhakar.csengg@gmail.com
davinci_dm6467Tevm In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h. The substantial difference between the davinci_dm6467evm and the davinci_dm6467Tevm configuration is a single bit in the hardware revision that is passed to the Linux kernel and davinci_dm6467evm has REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a REFCLK_FREQ = 33000000. This patch removes include/configs/davinci_dm6467Tevm.h. Instead the include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined in boards.cfg. Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-02-27da850evm: read mac address from I2C EEPROM on AM18x EVMHadli, Manjunath
add support to read mac address for AM18x EVM manufactured from Spectrum digital which have mac address stored in I2C EEPROM manufactured by WINBOND. This patch reads mac address from I2C EEPROM and sets the environment variable if not set, If mac address is already present in environment compare it with the mac address in EEPROM and warn on mismatch.Introduced a config option CONFIG_MAC_ADDR_IN_EEPROM to where to look for the mac address. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2012-02-27da850evm: add support to read mac address from SPI flashHadli, Manjunath
add support to read mac address for da850/L138 evm manufactured by Logic PD which store mac address in SPI flash manufactured by ST Microelectronics. This patch adds support to read mac address from SPI flash and set the mac address if it hasn't been set in environment, If it has been set in the environment it compares the value one with SPI flash and warns on mismatch. Introduced a config option CONFIG_MAC_ADDR_IN_SPIFLASH indicating where to look mac address for. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2011-12-24arm, da850evm: Add an SPL for SPI bootChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
2011-12-06da850evm: pass board revision info to kernelManjunath Hadli
there are two boards based on da850 SOC - OMAP-L138 and AM18x. In order to differentiate between these two boards, revision id is passed to kernel via second byte of ATAG_REVISION. Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com> Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
2011-12-06arm, davinci: move misc function in arch treeHeiko Schocher
move the board/davinci/common/misc.c file to arch/arm/cpu/arm926ejs/davinci/misc.c, so all davinci boards can use this functions. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Christian Riesch <christian.riesch@omicron.at>
2011-12-06arm, board/davinci/common/misc.c: Codingstyle cleanupHeiko Schocher
2011-12-06arm, hawkboard: Use the pinmux configurations defined in the arch treeChristian Riesch
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors that contain pinmux configurations for emac, uarts, memory controllers... In an earlier patch such pinmux configurations were added to the arch tree. This patch makes the hawkboard use these definitions instead of defining its own. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06arm, da850evm: Use the pinmux configurations defined in the arch treeChristian Riesch
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors that contain pinmux configurations for emac, uarts, memory controllers... In an earlier patch such pinmux configurations were added to the arch tree. This patch makes the da850evm use these definitions instead of defining its own. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06arm, da850evm: Do pinmux configuration for EMAC together with other pinmuxesChristian Riesch
Pinmux configuration for the EMAC was done in a separate call of davinci_configure_pin_mux(). This patch moves all the pinmux configuration that is done for this board to a common place. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06arm, hawkboard: Remove obsolete struct pinmux_config i2c_pinsChristian Riesch
The configuration in struct pinmux_config i2c_pins does not configure the pins for i2c but for uart. Since this function is already configured by struct pinmux_config uart2_pins the i2c_pins struct is obsolete. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06arm, davinci: Move pinmux functions from board to arch treeChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Nick Thompson <nick.thompson@ge.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Nick Thompson <nick.thompson@ge.com>
2011-11-29hawkboard: Replace HAWKBOARD_KICK{0, 1}_UNLOCK definesChristian Riesch
This patch replaces the HAWKBOARD_KICK{0,1}_UNLOCK defines by DV_SYSCFG_KICK{0,1}_UNLOCK. The kick register values are not hawkboard specific but may be used for all davinci boards. In commit f3c149d6c6e5ba8dd72baa86fe527837e4fb0e9a new defines for these values wer introduced. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-29davinci_sonata: define CONFIG_MACH_TYPE for davinci_sonata boardChristian Riesch
This patch fixes the build breakage for the davinci_sonata board. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sergey Kubushyn <ksi@koi8.net> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-29davinci_schmoogie: define CONFIG_MACH_TYPE for davinci_schmoogie boardChristian Riesch
This patch fixes the build breakage for the davinci_schmoogie board. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sergey Kubushyn <ksi@koi8.net> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-08dm646x: pass board revision info to kernelManjunath Hadli
add a function in board file to pass board revision info to kernel. Revision number 0 and 1 are passed in case of DM6467 and DM6467T respectively. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: added I2C supportStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: added video supportStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> Cc: Anatolij Gustschin <agust@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: add gpios for LCD backlight controlBastian Ruppert
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: add gpio for keeping power on in board_late_initBastian Ruppert
The pin called HALTEN drives a transistor to operate the supply voltage. After HALTEN is high, the user can release the power switch button and the device will stay powered on. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: sbabic@denx.de CC: dzu@denx.de Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
