path: root/board/davinci
2008-10-13ARM DaVinci: Remove redundant setting of GD_FLG_RELOC for sffsdr board.Hugo Villeneuve
This is no longer necessary now that the GD_FLG_RELOC flag is set for all ARM boards. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-08-30ARM DaVinci: Standardize names of directories/filesHugo Villeneuve
ARM DaVinci: Standardize names of directories/files. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-30ARM DaVinci: Move common functions to board/davinci/commonHugo Villeneuve
ARM DaVinci: Move common functions to board/davinci/common. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-14ARM DaVinci: Remove extern phy_t declaration by moving code to proper placeHugo Villeneuve
ARM DaVinci: Remove extern phy_t declaration by moving code to proper place. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-14ARM DaVinci: Remove duplicate definitions of MACH_TYPE and prototype of ↵Hugo Villeneuve
i2c_init() ARM DaVinci: Remove duplicate definitions of MACH_TYPE and prototype of i2c_init(). Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-10ARM: Fix for wrong patch version applied for Lyrtech SFF-SDR board (ARM926EJS)Hugo Villeneuve
ARM: Fix for incorrect version of patch applied when adding support for the Lyrtech SFF-SDR board. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Philip Balister, OpenSDR <philip@opensdr.com>
2008-07-02Cleanup: remove redundant deleting on *~ filesWolfgang Denk
2008-06-28ARM: Add support for Lyrtech SFF-SDR board (ARM926EJS)Hugo Villeneuve
This patch adds support for the Lyrtech SFF-SDR board, based on the TI DaVinci architecture (ARM926EJS). Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Philip Balister <philip@balister.org> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-09-15Make DECLARE_GLOBAL_DATA_PTR global for DaVinciDirk Behme
As discussed in [1], DECLARE_GLOBAL_DATA_PTR has to be global and not function local. Signed-off-by: Dirk Behme <dirk.behme@gmail.com> [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/31805
2007-08-14TI DaVinci - fix unsupported %hhx formatksi@koi8.net
Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
