path: root/board/davinci/sonata/config.mk
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
