path: root/board/davinci/schmoogie
2011-11-29davinci_schmoogie: define CONFIG_MACH_TYPE for davinci_schmoogie boardChristian Riesch
This patch fixes the build breakage for the davinci_schmoogie board. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sergey Kubushyn <ksi@koi8.net> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-28Move and rename common headers from underSughosh Ganu
board/davinci. Move the davinci common headers to the architecture specific include file path. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-18schmoogie: fix build error due to removal of forceenv()Wolfgang Denk
commit 6d014adf dropped support for the forceenv() function, but failed to remove references to it from board/davinci/schmoogie/schmoogie.c Replace forceenv() by setenv() and set CONFIG_ENV_OVERWRITE instead in the board config file to allow overwriting the serial number. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net> Acked-by: Sergey Kubushyn <ksi@koi8.net>
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2009-06-15Switched davinci_emac Ethernet driver to use newer APIBen Warren
Added CONFIG_NET_MULTI to all Davinci boards Removed all calls to Davinci network driver from board code Added cpu_eth_init() to cpu/arm926ejs/cpu.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12ARM DaVinci:Consolidate common u-boot.ldsSandeep Paulraj
The u-boot.lds is common for all DaVinci boards. The patch removes multiple instances and moves the u-boot.lds to /cpu/arm926ejs/davinci folder. This addresses one of the comments i received while submitting patches for DM3xx Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-06-12davinci: display correct clock infoDavid Brownell
Move the clock-rate dumping code into the cpu/.../davinci area where it should have been, enabled by CONFIG_DISPLAY_CPUINFO, updating the format and showing the DSP clock (where relevant). Switch boards to use the cpuinfo() hook for this stuff. Remove a few now-obsolete PLL #defines. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12davinci: move psc support board-->cpuDavid Brownell
Move DaVinci PSC support from board/* to cpu/* where it belongs. The PSC module manages clocks and resets for all DaVinci-family SoCs, and isn't at all board-specific. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-02-22ARM DaVinci: Add common peripherals and modules enable functions.Hugo Villeneuve
Taken all the duplicated code for enabling common modules and apply software workarounds from the board specific code into common functions. Also added comments explaining the workarounds (from TI errata documents) and replaced some numerical bit numbers with more meaningful defines. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-08-30ARM DaVinci: Standardize names of directories/filesHugo Villeneuve
ARM DaVinci: Standardize names of directories/files. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-30ARM DaVinci: Move common functions to board/davinci/commonHugo Villeneuve
ARM DaVinci: Move common functions to board/davinci/common. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-14ARM DaVinci: Remove extern phy_t declaration by moving code to proper placeHugo Villeneuve
ARM DaVinci: Remove extern phy_t declaration by moving code to proper place. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-14ARM DaVinci: Remove duplicate definitions of MACH_TYPE and prototype of ↵Hugo Villeneuve
i2c_init() ARM DaVinci: Remove duplicate definitions of MACH_TYPE and prototype of i2c_init(). Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-02Cleanup: remove redundant deleting on *~ filesWolfgang Denk
2007-09-15Make DECLARE_GLOBAL_DATA_PTR global for DaVinciDirk Behme
As discussed in [1], DECLARE_GLOBAL_DATA_PTR has to be global and not function local. Signed-off-by: Dirk Behme <dirk.behme@gmail.com> [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/31805
2007-08-14TI DaVinci - fix unsupported %hhx formatksi@koi8.net
Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
