path: root/board/davinci/dvevm
2009-06-15Switched davinci_emac Ethernet driver to use newer APIBen Warren
Added CONFIG_NET_MULTI to all Davinci boards Removed all calls to Davinci network driver from board code Added cpu_eth_init() to cpu/arm926ejs/cpu.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12ARM DaVinci:Consolidate common u-boot.ldsSandeep Paulraj
The u-boot.lds is common for all DaVinci boards. The patch removes multiple instances and moves the u-boot.lds to /cpu/arm926ejs/davinci folder. This addresses one of the comments i received while submitting patches for DM3xx Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-06-12davinci: display correct clock infoDavid Brownell
Move the clock-rate dumping code into the cpu/.../davinci area where it should have been, enabled by CONFIG_DISPLAY_CPUINFO, updating the format and showing the DSP clock (where relevant). Switch boards to use the cpuinfo() hook for this stuff. Remove a few now-obsolete PLL #defines. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-06-12davinci: move psc support board-->cpuDavid Brownell
Move DaVinci PSC support from board/* to cpu/* where it belongs. The PSC module manages clocks and resets for all DaVinci-family SoCs, and isn't at all board-specific. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-02-22ARM DaVinci: Add common peripherals and modules enable functions.Hugo Villeneuve
Taken all the duplicated code for enabling common modules and apply software workarounds from the board specific code into common functions. Also added comments explaining the workarounds (from TI errata documents) and replaced some numerical bit numbers with more meaningful defines. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2009-02-12Coding style cleanup; update CHANGELOGWolfgang Denk
2009-01-28usb : musb : Enabling DM6446 (TI DaVinci) USB module powerThomas Abraham
Enabling DM6446 (TI DaVinci) USB module power and MUSB low-level controller hook up to USB core layer. Signed-off-by: Ravi Babu <ravibabu@ti.com> Signed-off-by: Swaminathan S <swami.iyer@ti.com> Signed-off-by: Thomas Abraham <t-abraham@ti.com> Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-01-28usb : musb : Adding USB VBUS enable functionality for DM644x DVEVMThomas Abraham
Adding USB VBUS enable functionality for DM644x DVEVM (TI DaVinci) platform. Signed-off-by: Ravi Babu <ravibabu@ti.com> Signed-off-by: Swaminathan S <swami.iyer@ti.com> Signed-off-by: Thomas Abraham <t-abraham@ti.com> Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2008-08-30ARM DaVinci: Standardize names of directories/filesHugo Villeneuve
ARM DaVinci: Standardize names of directories/files. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
