path: root/board/davinci/dm6467evm
2011-02-02DaVinci DM6467: Enhance board SupportSandeep Paulraj
Support for DM6467 was incomplete and the build failed as well. Patches were sent to the list but have not been added. This enhances the DM6467 support. Some more patches will need to be sent to bring it in line with what is available in internal TI trees Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-11-27TI DaVinci DM646x: Enable NAND on DM6467 EVMSandeep Paulraj
This patch enables NAND on the DM6467 EVM Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-10-18TI DaVinci DM646x: Adding initial support for DM6467 EVMSandeep Paulraj
This patch adds the initial support for DM6467 EVM. Other features like NET and NAND support will be added as follow up patches. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
