path: root/board/davinci/dm365evm/dm365evm.c
2011-08-03DaVinci: rename gpio_defs.h to gpio.hLaurence Withers
In preparation for a generic GPIO driver for the DA8xx processors, rename <asm/arch/gpio_defs.h> to <asm/arch/gpio.h> and fix up all files which include it. Signed-off-by: Laurence Withers <lwithers@guralp.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02DaVinci DM365: Adding MMC/SD support for DM365 EVMSandeep Paulraj
The patch adds support for MMC/SD in the DM365 EVM Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-28Move and rename common headers from underSughosh Ganu
board/davinci. Move the davinci common headers to the architecture specific include file path. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-11davinci_emac: davinci_eth_set_mac_addr to ->write_hwaddrBen Gardiner
This patch proposes to migrate the davinci_emac driver to using the eth_device->write_hwaddr function pointer as suggested by Ben Warren. All the davinci boards had the behaviour, prior to this patch, of sync'ing the environment variable enetaddr with the MAC address read from non-volatile storage on boot -- when the two locations disagreed, the environment variable value took precendence. This patch keeps the same behaviour but lets eth_initialize take care of it. This patch refactors davinci_emac setup in the boards so that the MAC address is read from non-volatile storage into the environment variable and then the environment variable value is use in eth_intialize. The only exception is the direct call to davinci_eth_set_mac_addr made by the da830evm board init which was changed into an assignment of the enetaddr field. Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Tested-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-24TI DaVinci: Adding Copyright for DM365 EVMSandeep Paulraj
Forgot to add Copyright while submitting the patch. This patch adds the copyright. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-18TI DaVinci DM365: Fix Compilation warning for DM365 EVMSandeep Paulraj
This patch fixes a compilation warning while compiling the DM365 EVM. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-13TI: DaVinci DM365: Enabling network Support on DM365 EVMSandeep Paulraj
This patch enables EMAC on the DM365 EVM. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13TI DaVinci DM365: Removing header file which does not existSandeep Paulraj
The DaVinci DM365 EVM board specific code was including a header file which does not exist. So removing this header file. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-09-05ARM: DaVinci: Adding Support for DaVinci DM365 EVMSandeep Paulraj
This patch adds support for the DM365 EVM. It has been tested on a DM365 EVM. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
