Apparently the indentation is wrong in this case, as the second message
should be printed indepdently of the if statement.
Fix this indentation to avoid both compiler warnings and puzzled readers.
Pointed out by GCC 6.2's -Wmisleading-indentation warning.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
Use "_ethaddr" at the end of variables and drop CamelCase.
Make constant values actually 'const'.
The definitions inside emif_defs.h concern davinci nand driver and
should be in it's header. So create header file for davinci nand
driver and move definitions from emif_defs.h and nand_defs.h to it.
Acked-by: Vitaly Andrianov <vitalya@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
[trini: Fixup more davinci breakage]
The current code uses clrbits_be32 which is incorrect since we are on
a little endian machine here. This patch fixes this issue and also removes
some unnecessary code: Reading the current GPIO bank state is not required
if we are using the SET and CLEAR GPIO registers for setting/clearing
bits.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com>
Cc: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
[trini: Fixup common/cmd_io.c]
Though Commit id a3f88293ddd13facd734769c1664d35ab4ed681f (da850evm:
setup the NAND flash timings) has configured the AEMIF timings, they
are not exactly in sync with the timings used in Linux. Linux is
configuring the timing register as 0x08222204, where as currently it
configured to 0x00100084 in U-Boot. This issue was found out when
support for NAND SPL is added in U-Boot. Without this patch U-Boot
does not come up with SPL.
Tested-by: Christian Riesch <christian.riesch@omicron.at>
Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com>
Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
AHCLKR/UART1_RTS/GP0[11] pin needs to be configured for
MMC and NOR to work on DA850/OMAP-L138 Rev.3 EVM. When
GP0[11] is low, the SD0 interface will not work, but NOR
flash will. When GP0[11] is high, SD0 will work but NOR
flash will not.
This patch adds support for MMC/SD on DA850/OMAP-L138.
add support to read mac address for AM18x EVM manufactured from
Spectrum digital which have mac address stored in I2C EEPROM manufactured
by WINBOND. This patch reads mac address from I2C EEPROM and sets the
environment variable if not set, If mac address is already present in
environment compare it with the mac address in EEPROM and warn on
mismatch.Introduced a config option CONFIG_MAC_ADDR_IN_EEPROM to where
to look for the mac address.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Tom Rini <trini@ti.com>
Cc: Mike Frysinger <vapier@gentoo.org>
add support to read mac address for da850/L138 evm manufactured by
Logic PD which store mac address in SPI flash manufactured by ST
Microelectronics. This patch adds support to read mac address from
SPI flash and set the mac address if it hasn't been set in environment,
If it has been set in the environment it compares the value one with
SPI flash and warns on mismatch. Introduced a config option
CONFIG_MAC_ADDR_IN_SPIFLASH indicating where to look mac address for.
This patch moves hawkboard to the new spl infrastructure from the
older nand_spl one.
Removed the hawkboard_nand_config build option -- The spl code now
gets compiled with hawkboard_config, after building the main u-boot
image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard
to reflect the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
there are two boards based on da850 SOC - OMAP-L138 and AM18x.
In order to differentiate between these two boards, revision id
is passed to kernel via second byte of ATAG_REVISION.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors
that contain pinmux configurations for emac, uarts, memory controllers...
In an earlier patch such pinmux configurations were added to the arch
tree. This patch makes the da850evm use these definitions instead of
defining its own.
Acked-by: Heiko Schocher <hs@denx.de>
Pinmux configuration for the EMAC was done in a separate call
of davinci_configure_pin_mux(). This patch moves all the pinmux
configuration that is done for this board to a common place.
Cc: Syed Mohammed Khasim <sm.khasim@gmail.com>
Cc: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Nick Thompson <nick.thompson@ge.com>
Acked-by: Nick Thompson <nick.thompson@ge.com>
Since commit f1d2b313c9eb6808d30c16a9eb5251240452a56c the serial
port of the da850evm is accessed before the UART2 peripheral of
the SoC is powered on in the function board_init() in
board/davinci/da8xxevm/da850evm.c.
When u-boot is used in conjunction with the UBL (user boot loader, see
doc/README.davinci) on this board, the UART2 peripheral is already
turned on by UBL at the time u-boot is started. Hence, the wrong
initialization sequence is not noticed by most users. However, if UBL is not
used, u-boot must power on the peripheral before using it.
This patch adds a board_early_init_f() function for the LPSC
configuration to the da850evm board configuration.
Cc: Ben Gardiner <bengardiner@nanometrics.ca>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
NOR to work on Rev.3 EVM. When GP0[11] is low,
the SD0 interface will not work, but NOR flash will.
Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com>
add support for DSP wake-up by default on DA850/OMAP-L138
during board initialization. Enable hwconfig environment and added
extra env setting through CONFIG_EXTRA_ENV_SETTINGS.
To prevent DSP from being woken up,set the environment variable as,
set hwconfig "dsp:wake=no"
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Add pin-mux support for NOR in board file and correspanding
macros to use NOR boot mode in configuration file.
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
The current NAND timings, introduced in commit
a3f88293ddd13facd734769c1664d35ab4ed681f da850evm: setup the NAND flash
timings , incorrectly set WSTROBE and TA to 0. A more recent inspection of the
values set by the Linux kernel indicates that these should be set to 1.
Set the WSTROBE and TA field of the EMIFA cycle-count timings configuration to
1 to match the values set by linux.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
CC: Stefano Babic <sbabic@denx.de>
CC: Sandeep Paulraj <s-paulraj@ti.com>
CC: Scott Wood <scottwood@freescale.com>
As more Davinci 8xx board can be added, move common code
to be shared between boards.
* rebased ontop of Sugosh's patches
* moving the HAWKBOARD_KICK{0,1}_UNLOCK defines to
arch/arm/include/asm/arch-davinci/davinci_misc.h from to
arch/arm/include/asm/arch-davinci/da8xx_common.h
* don't define dram functions in PRELOADER
* move sync_env_enetaddr into existing EMAC ifdef
* use misc.c in hawkboard nand_spl
This patch is a port of the work by Sudhakar Rajeshekhara in commit
ab3effbcad8851cc65dc5241a01c064d2030a3b2 of
git://arago-project.org/git/people/sandeep/u-boot-davinci.git.
The da850 UI board has on it an RMII PHY which can be used if the MDC line
to the MII PHY on the baseboard is disabled and the RMII PHY is enabled by
configuring the values of some GPIO pins on the IO expander of the UI board.
This patch implements disabling that line via GPIO2[6], configuring the UI
board's IO expander and setting only the pinmux settings that are needed for
RMII operation.
Tested on da850evm by adding a define for CONFIG_DRIVER_TI_EMAC_USE_RMII.
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Mike Frysinger <vapier@gentoo.org>
CC: Sughosh Ganu <urwithsughosh@gmail.com>
board/davinci.
Move the davinci common headers to the architecture specific
include file path.
The TI DA850/OMAP-L138/AM18x EVM can be populated with devices
having different maximum allowed CPU clock rating.
The maximum clock the chip can support can only be determined from
the label on the package (not software readable).
Introduce a method to pass the maximum allowed clock rate information
to kernel using ATAG_REVISION. The kernel uses this information to
determine the maximum cpu clock rate reachable using cpufreq.
Note that U-Boot itself does not set the CPU clock rate. The CPU
clock is setup by a primary bootloader ("UBL"). The rate setup by
UBL could be different from the maximum clock rate supported by the
device.
The current da850evm support in u-boot/master omits any use of
the davinci EMAC. This patch adds basic support for the EMAC using
the MII PHY found on the baseboard of the EVM. The MAC address is
read from the environment variable 'ethadd'. Note that this is
different from the da850evm support in the u-boot omapl1 tree
where the MAC address is read from SPI flash.
CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
The default NAND flash timings are very conservative. This patch assigns the
timings reccomended in the recent linux kernel patch [1] from Sekhar Nori. The
speedup, as reported in that patch, is 5.3x for reads.
[1] http://www.spinics.net/lists/arm-kernel/msg100278.html
CC: Sekhar Nori <nsekhar@ti.com>
There is currently no NAND pinmux enabled by the da850evm board setup code.
This is fine when booting from NAND since the early boot code (UBL) will setup
the pinmux; however, when the boot mode is any other setting NAND is unusable
when enabled in the config.
This patch adds a pinmux list for NAND and enables it when NAND is enabled in
the config. Tested by booting from SPI on the da850evm and verifying NAND
was usable.
CC: Nick Thompson <nick.thompson@ge.com>
Usage of parenthesis in pinmux macro definition changes the
definition of the macro and raises the precedence of '&'
operator inadvertently over '[]'.
Signed-off-by: Prakash PM <prakash.pm@ti.com>
Provides initial support for TI OMAP-L138/DA850 SoC devices on
a Logic PD EVM board.
Provides:
Initial boot and configuration.
Support for i2c.
UART support (console).
Acked-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Wolfgang Denk <wd@denx.de>
