There was for long time no activity in the mpx5xxx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in mpc5xxx,
so remove it.
This option is pretty old. It predates CONFIG_SYS_I2C which is itself
deprecated in favour of driver model. Disable it for all boards.
Also drop I2C options which depend on this.
This allows us to use the same DRAM init function on all archs. Add a
dummy function for arc, which does not use DRAM init here.
[trini: Dummy function on nios2]
At present we cannot use this function as an init sequence call without a
wrapper, since it returns the RAM size. Adjust it to set the RAM size in
global_data instead, and return 0 on success.
It looks like only cm5200 and tqm8xx use this feature, so we don't really
need it in generic code. Drop it and have the users access gd->board_type
directly.
Since CONFIG_OF_BOARD_SETUP depends on CONFIG_OF_LIBFDT:
config OF_BOARD_SETUP
bool "Set up board-specific details in device tree before boot"
depends on OF_LIBFDT
remove superfluous tests of CONFIG_OF_LIBFDT when testing for
CONFIG_OF_BOARD_SETUP.
[trini: Typo fix: s/ifdefi/ifdef/]
This board has not been converted to generic board by the deadline.
Remove it.
This function can fail if the device tree runs out of space. Rather than
silently booting with an incomplete device tree, allow the failure to be
detected.
Unfortunately this involves changing a lot of places in the code. I have
not changed behvaiour to return an error where one is not currently
returned, to avoid unexpected breakage.
Eventually it would be nice to allow boards to register functions to be
called to update the device tree. This would avoid all the many functions
to do this. However it's not clear yet if this should be done using driver
model or with a linker list. This work is left for later.
Acked-by: Anatolij Gustschin <agust@denx.de>
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
Only define enabled clocks in the config file and enable
the clocks in common code.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Remove CSx configurations from board code and only define
required CSx macros in the board config file to configure
chip select windows and parameters.
Use a common watchdog driver for all these cpus.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
The PMIC framework has been extended to support multiple instances of
the variety of devices responsible for power management.
This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB
Interface Circuit).
Power related includes have been moved to ./include/power directory.
This is a first of a series of patches - in the future "pmic" will be
replaced with "power".
Two important issues:
1. The PMIC needs to be initialized just after malloc is configured
2. It uses list to hold information about available PMIC devices
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Use generic function for configuring GPR register.
On qong board some of the USBH2 pins are set via GPR register, so don need to setup
the IOMUX for each pin individually.
Other than that, these pins should not be configured as primary function because the primary
function selects SSI functionality.
Let GPR register do the work and remove the unneeded IOMUX setup.
Instead of writing directly to the GPR register, use mx31_set_gpr to setup USBH2 pins.
Fix checkpatch warning and errors in several i.MX related files.
While at it also address a checkpatch warning at arch/arm/cpu/armv7/mx5/soc.c
regarding the usage of extern in a C file.
Switch to new pmic generic driver.
setup_weimcs() and some macros are added to support the setup
for i.MX31 WEIM chip selects. As a compromise between verbosity
and readability an ASCII-art'ish bit comment is used instead of
bitfields.
All i.MX31 boards have been patched to use this approach using a
helper program to verify the changes.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Checkpatch.pl complains about the volatile qualifier in calls to
get_ram_size(). Remove this qualifier in the prototype and in the
calls where it is useless, and leave it only in the function body
where it is needed.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Remove obsolete config.mk from QONG board.
As exception among the i.MX processors, the i.MX31 has headers
without general names (mx31-regs.h, mx31.h instead of imx-regs.h and
clock.h). This requires several nasty #ifdef in the drivers to
include the correct header. The patch cleans up the driver and
renames the header files as for the other i.MX processors.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
The patch adds the possibility to update the QONG
FPGA (a Lattice XP2-5E) with u-boot using some GPIOs
to drive the JTAG interface.
The patch adds support for setting gpios to the
MX51 processor and change name to the corresponding
functions for MX31. In this way, it is possible to get rid
of nasty #ifdef switches related to the processor type.
Move common code to the fsl_diu_fb.c file and remove obsolete
code from board files (aria, mpc8610hpcd and pdm360ng).
Move fsl_diu_fb.h file to the include directory.
Change the implementation for ARM11 to relocate the code to an
arbitrary address in RAM.
Tested on the qong board.
Portions of this work were supported by funding from
the CE Linux Forum.
Add support for the PMIC (MC13783) controller
and enables charging of the RTC battery.
QONG is a module that can be installed on several boards,
not only on the QONG-EVB manufactured by Dave srl.
The QONG module can be downsized and delivered
with 128MB instead of 256MB. The patch adds
run time support for the two different memory
configurations.
The NAND device is connected to the FPGA of the QONG board
and not to the NFC controller. For this reason, the FPGA must
be set and initialized before accessing to the NAND itself.
u-boot updates, before starting Linux, the memory node in the
DTS. As this is a "standard" feature, move this functionality
to the cpu.c file for mpc5xxx and mpc512x processors.
Signed-off-by: Martha M Stan <mmarx@silicontkx.com>
Minor cleanup:
Re-ordered default_mddrc_config[] to have matching indices.
This allows to use the same index "N" for source and target fields;
before, we had code like this
out_be32(&im->mddrc.ddr_time_config2, mddrc_config[3]);
which always looked like a copy & paste error because 2 != 3.
Also, use NULL when meaning a null pointer.
Now that we have 3 boards for the MPC512x it turns out that they all
use the very same fixed_sdram() code.
This patch factors out this common code into cpu/mpc512x/fixed_sdram.c
and adds a new header file, include/asm-ppc/mpc512x.h, with some
macros, inline functions and prototype definitions specific to MPC512x
systems.
