path: root/board/dave
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-07-31Minor fixes for PPChameleon Board:Wolfgang Denk
* fix alignment of NAND size * make code do what the comment says
2005-05-04Use linker ASSERT statement to prevent undetected overlapping ofwdenk
sections on PPChameleon board; other boards might use this, too.
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
2004-07-01Patch by Andrea Marson, 11 Jun 2004:wdenk
Update for PPChameleon board: - support for SysClk @ 25MHz - support for Silicon Motion SM712 VGA controller - some clean ups
2004-06-17* Fix flash parameters passed to Linux for PPChameleon boardwdenk
* Remove eth_init() from lib_arm/board.c; it's done in net.net.c.
2004-04-18* Patch by Yasushi Shoji, 07 Apr 2004:wdenk
- add support for microblaze processors - add support for AtmarkTechno "suzaku" board
2004-04-18* Configure PPChameleon board to use redundand environment in flashLABEL_2004_04_18_2135wdenk
* Configure PPChameleon board to use JFFS2 NAND support. * Added support for JFFS2 filesystem (read-only) on top of NAND flash
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-02-24Add missing board/dave/B2/B2.c file.LABEL_2004_02_24_0305wdenk
2004-02-24* Patch by Andrea Scian, 17 Feb 2004:wdenk
Add support for S3C44B0 processor and DAVE B2 board * Patch by Steven Scholz, 20 Feb 2004: - Add support for MII commands on AT91RM9200 boards - some cleanup in AT91RM9200 ethernet code
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2003-10-22Fix PCI problems on PPChameleon boardwdenk
2003-10-06* Update TRAB auto update codeLABEL_2003_10_06_2355wdenk
* Make fatload set filesize environment variable fix potential buffer overlow problem * enable basic / medium / high-end configurations for PPChameleonEVB board; fix NAND code * enable TFTP client code to specify to the server the desired timeout value (see RFC-2349)
2003-09-11* Patch by Gary Jennejohn, 11 Sep 2003:wdenk
- allow for longer timeouts for USB mass storage devices * Patch by Denis Peter, 11 Sep 2003: - fix USB data pointer assignment for bulk only transfer. - prevent to display erased directories in FAT filesystem. * Change output format for NAND flash - make it look like for other memory, too
2003-09-03Adjustments / cleanup for PPChameleon EVB boardwdenk
2003-09-02* Add support for PPChameleon Eval Boardwdenk
* Add support for P3G4 board * Fix problem with MGT5100 FEC driver: add "early" MAC address initialization
