path: root/board/dave
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-11-09Moved PPC4xx EMAC driver to drivers/netBen Warren
Also changed path in all linker scripts that reference this driver Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-09-12Merge branch 'Makefile-next' of git://git.denx.de/u-boot-armWolfgang Denk
2008-09-12ppc4xx: Fix SDRAM inititialization of multiple 405 based board portsStefan Roese
This patch fixes a problem introdiced with patch bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by initdram()]. The boards affected are: - PCI405 - PPChameleonEVB - quad100hd - taihu - zeus Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Remove white space at end.William Juul
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-09board/[d-e]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-12-21Added support for the TQM8272 board from TQHeiko Schocher
2006-10-09Coding style cleanupWolfgang Denk
2006-04-12Merge with /home/m8/git/u-bootWolfgang Denk
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-06Minor code cleanupWolfgang Denk
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-02-24Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling.Bartlomiej Sieka
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-07-31Minor fixes for PPChameleon Board:Wolfgang Denk
* fix alignment of NAND size * make code do what the comment says
2005-05-04Use linker ASSERT statement to prevent undetected overlapping ofwdenk
sections on PPChameleon board; other boards might use this, too.
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
2004-07-01Patch by Andrea Marson, 11 Jun 2004:wdenk
Update for PPChameleon board: - support for SysClk @ 25MHz - support for Silicon Motion SM712 VGA controller - some clean ups
2004-06-17* Fix flash parameters passed to Linux for PPChameleon boardwdenk
* Remove eth_init() from lib_arm/board.c; it's done in net.net.c.
2004-04-18* Patch by Yasushi Shoji, 07 Apr 2004:wdenk
- add support for microblaze processors - add support for AtmarkTechno "suzaku" board
2004-04-18* Configure PPChameleon board to use redundand environment in flashLABEL_2004_04_18_2135wdenk
* Configure PPChameleon board to use JFFS2 NAND support. * Added support for JFFS2 filesystem (read-only) on top of NAND flash
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-02-24Add missing board/dave/B2/B2.c file.LABEL_2004_02_24_0305wdenk
2004-02-24* Patch by Andrea Scian, 17 Feb 2004:wdenk
Add support for S3C44B0 processor and DAVE B2 board * Patch by Steven Scholz, 20 Feb 2004: - Add support for MII commands on AT91RM9200 boards - some cleanup in AT91RM9200 ethernet code
