Pull common.c into common subdirectory of the board file,
since this code can be reused by other Data Modul SBCs.
Drop the include of lpddr4_timing.h, which is unneeded.
The icache is enabled in common architecture code since commit:
2fa763baa1c ("ARM: imx: Enable instruction cache early on on i.MX8M")
Drop the board side duplicate code.
Pull this LPGPR unlock into common code, since it is used in multiple
systems already.
Adjust the DRAM timing settings for this board per ones provided
by hardware department. The change is applied to the LPDDR4 MR11
register CA ODT configuration, from RZQ/6 to RZQ/3, which fixes
stability issues on subset of boards. The DDR PHY PIE block has
been updated accordingly.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Fabio Estevam <festevam@denx.de>
Replace the ad-hoc I2C register programming scripted in board
environment with U-Boot DM driver.
Enable CONFIG_SPL_DM_SERIAL. uart and its pinmux was already
marked with u-boot,dm-spl.
Move preloader_console_init after spl_early_init to make sure driver
model work.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add support for Data Modul i.MX8M Mini eDM SBC board. This is an
evaluation board for various custom display units. Currently
supported are serial console, ethernet, eMMC, SD, SPI NOR,
USB host and USB OTG.
