path: root/board/cu824
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-02Moved initialization of TULIP Ethernet controller to board_eth_init()Ben Warren
Affected boards: cu824 bab7xx adciop dasa_sim mousse mpc8540eval musenki mvblue pcippc2/pcippc6 sbc8240 stxssa Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-07-04Remove obsolete mpc824x linker scripts (1 of 4)Grant Likely
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-08-14Initial revisionwdenk
2002-04-01Initial revisionwdenk
2001-05-16Initial revisionwdenk
