path: root/board/cu824
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-08-14Initial revisionwdenk
2002-04-01Initial revisionwdenk
2001-05-16Initial revisionwdenk
