path: root/board/cu824/Makefile
2015-01-05powerpc: mpc824x: remove MPC824X cpu supportMasahiro Yamada
All the MPC824X boards are still non-generic boards: A3000, CPC45, CU824, eXalion, MVBLUE, MUSENKI, Sandpoint824x, utx8245 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Torsten Demke <torsten.demke@fci.com> Cc: Jim Thompson <jim@musenki.com> Cc: Greg Allen <gallen@arlut.utexas.edu>
2002-04-01Initial revisionwdenk
