path: root/board/cssi
2021-10-06nand.h: Cleanup linux/mtd/rawnand.h usageTom Rini
We only include <linux/mtd/rawnand.h> in <nand.h> for the forward declaration of struct nand_chip, so do that directly. Then, include <linux/mtd/rawnand.h> where required directly. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move serial functions out of common.hSimon Glass
These functions belong in serial.h so move them over. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-03board: MCR3000: use new DM watchdogChristophe Leroy
This patch switches MCR3000 board to the new DM watchdog. The change in u-boot.lds is because MCR3000.o grows a bit with this patch and doesn't fit anymore below env_offset on some versions of GCC. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-12-03board: MCR3000: Activate CONFIG_DM and CONFIG_OF_CONTROLChristophe Leroy
Add mcr3000 device tree and activate CONFIG_DM and CONFIG_OF_CONTROL Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-04-06board: MCR3000: Use smaller flash sector for environmentChristophe Leroy
Latest versions of u-boot have increased in size and require more than the 256kb allocated to it. The MCR3000 board is equipped with an AM29LV160DB boot flash which is organised as follows: - One 16kb block - Two 8kb block - One 32kb block - Thirty one 64kb blocks At the time being, u-boot is a single piece occupying the 256 first kbytes, then the environment is stored in the following 64kb block The environment being quite tiny, we save one 64kb block by embedding the environment in the first 8kb block, hence allowing to increase the monitor size to 320kb. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-04-06board: MCR3000: cleanup configChristophe Leroy
Some config is redundant with Kconfig. Fix it. Also remove unused configs Move SDRAM_MAX_SIZE in the only place it is used include/environment.h already defines CONFIG_ENV_SIZE from CONFIG_ENV_SECT_SIZE and defines CONFIG_ENV_ADDR as (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) remove BOOTARGS as bootargs is set by the different boot commands Fix CONFIG_SYS_INIT_RAM_ADDR and CONFIG_SYS_INIT_RAM_SIZE to be in line with CPM DPRAM organisation Remove CONFIG_SYS_GBL_DATA_SIZE, CONFIG_SYS_GBL_DATA_OFFSET and CONFIG_SYS_INIT_SP_OFFSET which are unused Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-04-06board: MCR3000: replace mtd->priv by mtd_to_nand()Christophe Leroy
Since commit 17cb4b8f327eb ("mtd: nand: Add+use mtd_to/from_nand and nand_get/set_controller_data"), mtd_to_nand() has to be used instead of mtd->priv Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-08powerpc, 8xx: Add support for MCR3000 board from CSSIChristophe Leroy
CS Systemes d'Information (CSSI) manufactures two boards, named MCR3000 and CMPC885 which are respectively based on MPC866 and MPC885 processors. This patch adds support for the first board. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
