path: root/board/csb637
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-10-09Eliminate hard-coded address of Ethernet transfer buffer on at91rm9200Wolfgang Denk
Patch by Anders Larsen, 07 Oct 2005 The Atmel errata #11 states that the transfer buffer descriptor table must be aligned on a 16-word boundary. As it turned out, this is insufficient - it seems the table must be aligned on a boundary at least as large as the table itself (in Linux this is not an issue - the table is aligned on a PAGE_SIZE (4096) boundary).
2005-10-06Fix the machine-id of the Cogent csb637 boardWolfgang Denk
Patch by Anders Larsen, 05 Oct 2005
2005-10-05Add support for Cogent csb637Wolfgang Denk
Patch by Anders Larsen, 29 Apr 2005
