path: root/board/csb472
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx SDRAM defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed some SDRAM defines. This patch now changes lower case UIC defines to upper case. Also some names are changed to match the naming in the IBM/AMCC users manuals (e.g. mem_mcopt1 -> SDRAM0_CFG). Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-09Dual-license IBM code contributionsJosh Boyer
It was brought to our attention that U-Boot contains code derived from the IBM OpenBIOS source code originally provided with some of the older PowerPC 4xx development boards. As a result, the original license of this code has been carried in the various files for a number of years in the U-Boot project. IBM is dual-licensing the IBM code contributions already present in U-Boot under either the terms of the GNU General Public License version 2, or the original code license already present. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-11-09Moved PPC4xx EMAC driver to drivers/netBen Warren
Also changed path in all linker scripts that reference this driver Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove superfluous dram_init() call or replace it by initdram()Stefan Roese
Historically the 405 U-Boot port had a dram_init() call in early init stage. This function was still called from start.S and most of the time coded in assembler. This is not needed anymore (since a long time) and boards should implement the common initdram() function in C instead. This patch now removed the dram_init() call from start.S and removes the empty implementations that are scattered through most of the 405 board ports. Some older board ports really implement this dram_init() though. These are: csb272 csb472 ERIC EXBITGEN W7OLMC W7OLMG I changed those boards to call this assembler dram_init() function now from their board specific initdram() instead. This *should* work, but please test again on those platforms. And it is perhaps a good idea that those boards use some common 405 SDRAM initialization code from cpu/ppc4xx at some time. So further patches welcome here. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2005-04-03* Patch by Mathias Küster, 23 Nov 2004:wdenk
add udelay support for the mcf5282 cpu * Patch by Tolunay Orkun, 16 November 2004: fix incorrect onboard Xilinx CPLD base address
2004-06-09Patch by Tolunay Orkun, 14 May 2004:wdenk
Add support for Cogent CSB472 board (8MB Flash Rev)
