path: root/board/csb226/lowlevel_init.S
2010-10-22PXA: csb226: Fix for relocMarek Vasut
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
