path: root/board/cray
2007-02-20[PATCH] PPC4xx: Add support for multiple I2C bussesStefan Roese
This patch adds support for multiple I2C busses on the PPC4xx platforms. Define CONFIG_I2C_MULTI_BUS in the board config file to make use of this feature. It also merges the 405 and 440 i2c header files into one common file 4xx_i2c.h. Also the 4xx i2c reset procedure is reworked since I experienced some problems with the first access on the 440SPe Katmai board. Signed-off-by: Stefan Roese <sr@denx.de>
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2003-05-22* Patch by Dave Ellis, 22 May 2003:LABEL_2003_05_23_0055wdenk
Fix problem with only partially cleared .bss segment * Patch by Rune Torgersen, 12 May 2003: get PCI to work on a MPC8266ADS board; incorporate change to cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2002-03-08Initial revisionwdenk
