path: root/board/cray/L1
2008-06-03ppc4xx: Remove superfluous dram_init() call or replace it by initdram()Stefan Roese
Historically the 405 U-Boot port had a dram_init() call in early init stage. This function was still called from start.S and most of the time coded in assembler. This is not needed anymore (since a long time) and boards should implement the common initdram() function in C instead. This patch now removed the dram_init() call from start.S and removes the empty implementations that are scattered through most of the 405 board ports. Some older board ports really implement this dram_init() though. These are: csb272 csb472 ERIC EXBITGEN W7OLMC W7OLMG I changed those boards to call this assembler dram_init() function now from their board specific initdram() instead. This *should* work, but please test again on those platforms. And it is perhaps a good idea that those boards use some common 405 SDRAM initialization code from cpu/ppc4xx at some time. So further patches welcome here. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-26Merge branch 'new-image' of git://www.denx.de/git/u-boot-testingBartlomiej Sieka
Conflicts: common/cmd_bootm.c cpu/mpc8xx/cpu.c Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-20LWMON5: POST RTC fixYuri Tikhonov
Modify the RTC API to provide one a status for the time reported by the rtc_get() function: 0 - a reliable time is guaranteed, < 0 - a reliable time isn't guaranteed (power fault, clock issues, and so on). The RTC chip drivers are responsible for providing this info if the corresponding chip supports such functionality. If not - always report that the time is reliable. The POST RTC test was modified to detect the RTC faults utilizing this new rtc_get() feature. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] PPC4xx: Add support for multiple I2C bussesStefan Roese
This patch adds support for multiple I2C busses on the PPC4xx platforms. Define CONFIG_I2C_MULTI_BUS in the board config file to make use of this feature. It also merges the 405 and 440 i2c header files into one common file 4xx_i2c.h. Also the 4xx i2c reset procedure is reworked since I experienced some problems with the first access on the 440SPe Katmai board. Signed-off-by: Stefan Roese <sr@denx.de>
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2003-05-22* Patch by Dave Ellis, 22 May 2003:LABEL_2003_05_23_0055wdenk
Fix problem with only partially cleared .bss segment * Patch by Rune Torgersen, 12 May 2003: get PCI to work on a MPC8266ADS board; incorporate change to cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2002-03-08Initial revisionwdenk
