path: root/board/cpu87
2006-09-04Merge with /home/m8/git/u-bootWolfgang Denk
2006-08-27Code cleanupWolfgang Denk
2006-07-22Add support for 256 MB SDRAM on CPU87Wolfgang Denk
Patch by Josef Wagner, 25 Nov 2005
2005-04-03Patches by Josef Wagner, 29 Oct 2004:wdenk
- Add support for MicroSys CPU87 board - Add support for MicroSys PM854 board
