path: root/board/cpc45
2010-11-27824x: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Remove obsolete mpc824x linker scripts (1 of 4)Grant Likely
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-07-10Major PCMCIA Cleanup to make code better readable and maintainable.Wolfgang Denk
Notes: - Board-dependend code for RPXLITE and RPXCLASSIC-based boards placed to the drivers/rpx_pmcia.c file to avoid duplication. Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c). - drivers/i82365.c has been split into two parts located at board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are the only boards using CONFIG_82365). - Changes were tested for clean build and *very* *few* boards.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-06-19Patch by Josef Wagner, 04 Jun 2004:wdenk
- DDR Ram support for PM520 (MPC5200) - support for different flash types (PM520) - USB / IDE / CF-Card / DiskOnChip support for PM520 - 8 bit boot rom support for PM520/CE520 - Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245) - I2C and RTC support for CPC45 - support of new flash type (28F160C3T) for CPC45
2004-06-01Fix text alignmentwdenk
