Recent cleanup actions resulted in a number of config.mk files that
contained only redundant entries like
PLATFORM_CPPFLAGS += -I$(TOPDIR)
or settings of variables that were not used anywhere in the code, like
TEXT_END = 0xfe080000
Remove these unnecessary files.
Cc: Scott McNutt <smcnutt@psyent.com>
Cc: Wolfgang Wegner <w.wegner@astro-kom.de>
Cc: Josef Wagner <Wagner@Microsys.de>
Cc: Tolunay Orkun <torkun@nextio.com>
Cc: Frank Panno <fpanno@delphintech.com>
Cc: Brad Kemp <Brad.Kemp@seranoa.com>
Acked-by: Heiko Schocher<hs@denx.de>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
