path: root/board/corscience
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-02-12OMAP3: Add Corscience Tricorder boardThomas Weber
Tricorder is a board which is very similar to the Devkit8000. It is designed as a base platform for further medical devices. www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html Signed-off-by: Thomas Weber <weber@corscience.de>
