path: root/board/corscience/tricorder
2014-04-11board:tricorder: always work with valid eeprom dataAndreas Bießmann
Commit 890880583d84607e36b52a785a96b167728bbf73 introduced EEPROM parsing and board detection but faild to return a valid tricorder_eeprom struct for backup case. When pressing S200 while reading EEPROM we ignore the value. We returned falsely a tricorder_eeprom struct with uninitialized data which is just garbage. Initialize it by zeroing the whole structure. Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de> Cc: Thomas Weber <thomas.weber@corscience.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-01tricorder: support 256MiB SDRAM on revision > DAndreas Bießmann
2013-11-01tricorder: add led supportAndreas Bießmann
2013-11-01tricorder: panic() on unknown boardAndreas Bießmann
Also hang() the board on panic(). Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de>
2013-11-01tricorder: add tricordereeprom commandAndreas Bießmann
The new tricordereeprom command can read and write the eeprom for hardware detection on tricorder devices. Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-12-10Pass sdrc timing values through board_sdrc_timings structurePeter Barada
Instead of passing individual registers by value to board_get_mem_timings, pass a board_mem_timings structure pointer for the board files to fill in. Pass same structure pointer to write_sdrc_timings. This saves about 90 bytes of space in SPL. Signed-off-by: Peter Barada <peter.barada@logicpd.com>
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-02-12OMAP3: Add Corscience Tricorder boardThomas Weber
Tricorder is a board which is very similar to the Devkit8000. It is designed as a base platform for further medical devices. www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html Signed-off-by: Thomas Weber <weber@corscience.de>
