path: root/board/corscience/tricorder/led.c
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2013-11-01tricorder: add led supportAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de>
