path: root/board/compulab
2012-10-15tegra20: rework UART GPIO handlingLucas Stach
Rename board provided gpio_config_uart() to gpio_early_init_uart() as it does the same thing as the equally called function provided by the uart-switch code. This allows to simply call this function in early board init whether or not we are building with CONFIG_UART_SWITCH defined. Also provide a weak symbol for this function, to avoid the need to provide this function for boards that don't need any fixup. This patch supersedes the earlier posted "tegra: convert gpio_config_uart to weak symbol". Build tested with MAKEALL -s tegra20 Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15Tegra20: Move some include files to arch-tegra for sharing with Tegra30Tom Warren
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h. Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20' 'root' file. All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-01tegra20: make board mkdir commands unconditionalAllen Martin
Change the mkdir commands for the object directories to be unconditional. This fixes an issue when building for SPL where SRCTREE and OBJTREE are the same, but $(obj) is under SPLTREE. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: trimslice: set up serial flash pinmuxStephen Warren
When Trimslice is booted from serial flash, the boot ROM does this, so U-Boot doesn't need to. However, booting from the SD slot for recovery purposes, the boot ROM does not set up the pinmux for serial flash. Add code to U-Boot to set this up, so that an SD-based recovery U-Boot image can upgrade the U-Boot in serial flash. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: fix leftover CONFIG_TEGRA2_MMC & _SPI build switchesTom Warren
Missed some boards after my tegra2_mmc.* -> tegra_mmc.* change, and one instance of CONFIG_TEGRA2_SPI. MAKEALL -s tegra2 AOK, Seaboard MMC AOK. Didn't test Tamonten, Paz00 or TrimSlice, as I have none here. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2012-07-07tegra: trimslice: fix a couple typosStephen Warren
Fix the .dts file USB unit addresses not to duplicate each-other. Fix the board name string to indicate the vendor is Compulab not NVIDIA. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-07-07tegra: Compulab TrimSlice board supportStephen Warren
