path: root/board/compulab
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-07-09arm: Remove cm_t35 boardJagan Teki
DM, DM_SPI and other driver model migration deadlines are expired for this board. Remove it. Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2020-07-09arm: Remove cm_t54 boardJagan Teki
DM, DM_SPI and other driver model migration deadlines are expired for this board. Remove it. Cc: Dmitry Lifshitz <lifshitz@compulab.co.il> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18arm: Don't include common.h in header filesSimon Glass
It is bad practice to include common.h in other header files since it can bring in any number of superfluous definitions. It implies that some C files don't include it and thus may be missing CONFIG options that are set up by that file. The C files should include these themselves. Update some header files in arch/arm to drop this. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-17common: Move RAM-sizing functions to init.hSimon Glass
These functions relate to memory init so move them into the init header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move clock functions into a new fileSimon Glass
These three clock functions don't use driver model and should be migrated. In the meantime, create a new file to hold them. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-07board: cm_fx6: Enable DM support for video, fix build errorSuniel Mahesh
Enable driver model for Video to remove the following compile warning on CM-FX6 SOM based target: ===================== WARNING ====================== This board does not use CONFIG_DM_VIDEO Please update the board to use CONFIG_DM_VIDEO before the v2019.07 release. ==================================================== This change introduced build error as shown: LD u-boot drivers/built-in.o: In function ipu_displays_init' arm-linux-ld.bfd: BFD (GNU Binutils) 2.29.1 assertion fail elf32-arm.c:9509 Makefile:1621: recipe for target 'u-boot' failed make: *** [u-boot] Error 1 The DM converted video driver calls ipu_displays_init in its probe, which inturn calls relevant board_video_skip. Defining ipu_displays_init in the board file fixes build error. Target was compile tested, build was clean. Signed-off-by: Suniel Mahesh <sunil.m@techveda.org>
2019-12-02common: Move old EEPROM functions into a new headerSimon Glass
These functions do not use driver model but are still used. Move them to a new eeprom.h header file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Drop global inclusion of status_led.hSimon Glass
This is only used by a few files so it should not be in the common header. Move it out. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-05-28cm_t3517: remove boardBartosz Golaszewski
This board still doesn't select CONFIG_DM and seems to be umaintained. As it makes progress on modernizing several DaVinci drivers more difficult and the maintainer has not expressed interest in updating it, this patch proposes to remove it. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-04-17arm: am57xx: cl-som-am57x: remove board supportUri Mashiach
U-Boot support for the CL-SOM-AM57x module is no longer required. Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2018-08-23usb: musb-new: Fix improper musb host pointerJagan Teki
When MUSB is operating in peripheral mode, probe registering musb core using musb_register which intern return int value for validation. so there is no scope to preserve struct musb pointer but the same can be used in .remove musb_stop. So fix this by return musb_register with struct musb pointer. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Purna Chandra Mandal <purna.mandal@microchip.com> Tested-by: Chen-Yu Tsai <wens@csie.org> # A33-OlinuXino Tested-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-07-25board: constify struct node_info arrayMasahiro Yamada
Add 'const' (also 'static' in some places) to struct node_info arrays to save memory footprint. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-22Revert "mx6: ddr: Allow changing REFSEL and REFR fields"Maxim Yu. Osipov
This reverts commit edf0093732225c2fd0791c3864e9a3eef1f92f19 for cm_fx6 iMX.6 Solo module as it causes frequent (around 10 percent of power cycles) board's hangs. These hangs happen in SPL when BSS is being initialized in SDRAM - it appear that variables from BSS contain trash values which lead to board hangs. Looks like that SDRAM doesn't yet finish initialization in these cases. Signed-off-by: Maxim Yu. Osipov <mosipov@ilbers.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-02-15usb: host: xhci-omap: Remove redundant board_usb_init and board_usb_cleanup ↵Faiz Abbas
functions board_usb_init()/_cleanup() should be in board files and don't have a place in the xhci-omap driver. Weak versions for board_usb_init()/_cleanup() already exist in common/usb.c (for host mode) and drivers/usb/gadget/g_dnl.c (for gadget mode). Therefore, remove init and cleanup functions from xhci-omap and implement them in the board files. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-01-12ARM: imx: cm_fx6: export board and soc info to envChristopher Spinrath
Like many other i.MX6 based boards, there are multiple variants of the cm-fx6 module featuring different SoC variants. Furthermore, the module can be paired with multiple baseboards. At the same time modern distribution like Fedora require U-Boot to select a proper devicetree which depends on the SoC variant and the baseboard. Thus, export the SoC variant and the actual board to the environment following the conventions of other i.MX6 devices (e.g. the NXP boards) such that the environment can select a devicetree file to load. For now, we only know for sure that the cm-fx6 module and the SB-fx6m baseboard amount to a Utilite Computer variant (depending on the SoC). Further combinations may be added in the future; e.g. CompuLab's evaluation board once someone can verify the identification string stored in its eeprom. Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2017-12-29ARM: imx: cm_fx6: remove esdhc init code from board fileChristopher Spinrath
Commit 5248930ebf48 ("dm: imx: cm_fx6: Enable more driver model support") enabled driver model support for MMC. Remove the old mmc init code, which is no longer used, from the board file. Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-29ARM: imx: cm_fx6: remove sata init code from board fileChristopher Spinrath
Commit 5248930ebf48 ("dm: imx: cm_fx6: Enable more driver model support") enabled driver model support for AHCI. Remove the old, now unused, sata init code from the board file. Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-26usb: hub: identify the hub-device to usb_hub_reset_devicesPhilipp Tomsich
When usb_hub_reset_devices is called, it should be passed both an indicator which hub it should operate on and what port number (local to that hub) should be reset. Previously, the usb_hub.c code did not include such context and always started resets from port number 1, performing multiple reset-requests for the same devices: /* * Reset any devices that may be in a bad state when applying * the power. This is a __weak function. Resetting of the devices * should occur in the board file of the device. */ for (i = 0; i < dev->maxchild; i++) usb_hub_reset_devices(i + 1); This adds an additional 'hub' parameter to usb_hub_reset_devices that provides the context to fully qualify the port-number in. Existing implementations are changed to accept and ignore the new parameter. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-12arm: imx7d: add support for Compulab cl-som-imx7Ilya Ledvich
Add initial support for Compulab cl-som-imx7 SoM. The initial support includes: - MMC - eMMC - SPI flash - I2C - FEC - USB - Serial console Signed-off-by: Ilya Ledvich <ilya@compulab.co.il>
2017-09-18imx6: drop duplicated bss memset and board_init_r() callAnatolij Gustschin
bss section is cleared in crt0.S. board_init_r() is also entered from crt0 code. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <lukma@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-09-14arm: am57xx: cl-som-am57x: Use new pinctrl macrosSuman Anna
Commit 6ae4c3efbd62 ("ARM: DRA7: Add pinctrl register definitions") has added new macros for pinmux configuration in line with the kernel definitions. Fixup the current pinctrl data for the CompuLab CL-SOM-AM57x board to use these new macros to facilitate the removal of the old macros. NOTE: The PEN and PDIS macro values used previously were actually defined inversely, a value of 1 in bit position 16 actually means that the internal pullup/pulldown is disabled and not enabled as inferred by PEN. So, previous pinmux config data such as (PDIS | PTU) is confusing as it actually was meant for enabling internal pullup. The data is fixed up only to be equivalent to the previous data. Signed-off-by: Suman Anna <s-anna@ti.com>
2017-08-18Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2017-08-17dm: imx: cm_fx6: Add MMC support for CONFIG_BLKSimon Glass
When CONFIG_BLK is enabled our weak board_mmc_init() will not be called. Since there is no clock driver for MX6 yet, we must manually enable the clocks. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: imx: cm_fx6: Support driver model for SATASimon Glass
Add support for using driver model for SATA with the cm_fx6 board. The old code remains for now to permit testing. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_getenv_enetaddr() to eth_env_get_enetaddr()Simon Glass
Rename this function for consistency with env_get(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-09Configs: Migrate CONFIG_SYS_I2C_OMAP34XX to CONFIG_SYS_I2C_OMAP24XXAdam Ford
The driver is for all boards 24XX and up, so let's eliminate the extra option called CONFIG_SYS_I2C_OMAP34XX since the driver checks for CONFIG_OMAP34XX we don't need CONFIG_SYS_I2C_OMAP34XX. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-06-05ARM: am57xx: cl-som-am57x: support for AM5718Uri Mashiach
Disable SDRAM controller EMIF2 for single core SOC Set SDRAM size size to 1GB Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-05arm: Include asm/setup.h explictlySimon Glass
Include this header where needed so we do not need to rely on common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-16Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
- Add #undef CONFIG_DM_MMC_OPS to omap3_logic in the SPL build case, to match other TI platforms in the same situation. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
