path: root/board/compulab
2014-12-18ARM: tegra: Enable PCIe on TrimSliceThierry Reding
The TrimSlice has an ethernet NIC connected to the PCIe bus. Enable the PCIe controller and the network driver so that the device can boot over the network. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-04omap_hsmmc: Board-specific TWL4030 MMC power initializationsPaul Kocialkowski
Boards using the TWL4030 regulator may not all use the LDOs the same way (e.g. MMC2 power can be controlled by another LDO than VMMC2). This delegates TWL4030 MMC power initializations to board-specific functions, that may still call twl4030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Fix omap3_evm warning, add twl4030.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-26Merge git://git.denx.de/u-boot-fdtTom Rini
2014-11-24arm: mx6: cm_fx6: implement board specific sata stopNikita Kiryanov
Provide board specific implementation for sata stop command for cm_fx6. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-11-20mx6: Use a common SPL configuration fileFabio Estevam
Many boards use a minimal .cfg file in the SPL case. Introduce spl_sd.cfg so that we can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-07Merge git://git.denx.de/u-boot-tiTom Rini
2014-11-06omap3: cm-t3517: add LCD/DVI and splash supportIgor Grinberg
Add support for splash screen on both DVI and SCF0403 LCD. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06omap3: cm-t3517: add Ethernet supportIgor Grinberg
Add both EMAC and SMC911x support. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06omap3: cm-t3517: add USB supportIgor Grinberg
Add both host and mUSB support. Currently, the selection between host USB and mUSB is done through the config file. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06omap3: cm-t3517: add basic board supportIgor Grinberg
CompuLab cm-t3517 is Computer on Module (CoM) based on AM3517 SoC. Features: up to 256MB DDR2, up to 512MB NAND, USB hub, mUSB, WiFi, BT, Analog audio codec, touch screen controller, LED. Add basic support including: LED, Serial console, NAND, MMC, GPIO, I2C, 256MB DRAM. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2014-11-06omap: hsmmc: assume cd gpio is active lowIgor Grinberg
Switch the default CD GPIO polarity to active low. The current hsmmc driver assumption that the CD GPIO is active high, but in the real hardware, usually the opposite holds. The usual SD card socket has a mechanical switch which is grounded as soon as a card is inserted. Of course there might be some board logic which inverts the signal, but as far as current users are concerned, there is no such logic. Current U-Boot users either not using the CD functionality, or have a different way (e.g. external to SoC GPIO controller) for checking the card presence. This patch also brings the polarity assumption in line with the Linux kernel and adds appropriate comments. This patch also might spare issues once the TWL GPIO driver will be converted to the DM. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Dmitry Lifshitz <lifshitz@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06omap3: cm-t35: move get_board_serial() fallbackIgor Grinberg
The fallback is used for cases when CONFIG_SERIAL_TAG defined, but the eeprom is not used. The fallback is useful for more than one CompuLab board, so move it to a common location. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06omap3: cm-t35: move the SMC911x codeIgor Grinberg
Extract the SMC911x initialization code to a common location where it can be reused by other compulab omap3 based boards. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06omap3: cm-t35: extract the splash code from boardIgor Grinberg
The splash screen loading code can be reused by other compulab boards. For now extract it to a common location for further reuse. This also switches the splash code dependency from CONFIG_LCD to CONFIG_SPLASH_SCREEN as it should normally be. In addition this patch fixes the accidental dependency of the get_board_mem_timings() function on CONFIG_LCD, by just moving the splash code and leaving the above function intact. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06omap3: cm-t35: move the USB hub reset codeIgor Grinberg
Extract the USB hub reset code to a common location where it can be reused by other compulab boards. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-06compulab: refactor board revision handlingIgor Grinberg
Move board revision handling code to a common location for further reuse. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-11-05arm: mx6: cm_fx6: detect 1GB DRAM correctly on soloNikita Kiryanov
The 1GB DRAM configuration on mx6 solo uses 2 chip selects, but the code tests 1GB DRAM configuration as if it is all present on one chip select, and thus cannot see the full range of available memory. Refactor the check to detect 1GB DRAM correctly. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-11-05arm: mx6: cm_fx6: change issd gpio orderNikita Kiryanov
Change the order in which GPIOs are toggled in SATA init sequence to accomodate both SanDisk and Phison SSDs. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27Merge branch 'master' of git://git.denx.de/u-boot-imxTom Rini
2014-10-27Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-10-23dm: move platform data headers to include/dm/platform_dataMasahiro Yamada
The platform_data definitions are generally referenced from both drivers and board files. That is why header files defining platform_data sturectures are placed in "include" directory, but our top level "include" directory is already too cluttered. Let's collect platform_data definitions under the directory "include/dm/platform_data" like Linux gathers ones around under "include/linux/platform_data". This commit moves two header files: include/serial_mxc.h -> include/dm/platform_data/serial_mxc.h include/serial_pl01x.h -> include/dm/platform_data/serial_pl01x.h Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-23omap3/am33xx: mux: fix several checkpatch issuesIgor Grinberg
Fix the following checkpatch issues: CHECK: No space is necessary after a cast \#39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39: +#define PAD_CTRL_BASE 0x800 +#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \ CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST> \#284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284: +#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C ERROR: space required after that ',' (ctx:VxV) \#446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat <raph@8d.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Nishanth Menon <nm@ti.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefan Roese <sr@denx.de>
2014-10-23omap3: cm-t35: remove enable_gpmc_cs_config()Igor Grinberg
The gpmc_init() function already calls enable_gpmc_cs_config() for chip select 0. Although the bus width is configured for 16 bit, it gets reconfigured correctly in the omap_gpmc driver later. Remove the enable_gpmc_cs_config() function call and the associated gpmc_nand_config[] array. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2014-10-23omap3: cm-t35: use define for mmc wp gpioIgor Grinberg
Switch to using define for MMC WP GPIO instead of a magic number. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2014-10-22dm: imx: Move cm_fx6 to use driver model for serial and GPIOSimon Glass
Now that serial and GPIO are available for iMX.6, move cm_fx6 over as an example. Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-10-22arm: mx6: cm_fx6: use gpio requestNikita Kiryanov
Use gpio_request for all the gpios that are utilized by various subsystems in cm-fx6, and refactor the relevant init functions so that all gpios are requested during board_init(), not during subsystem init, thus avoiding the need to manage gpio ownership each time a subsystem is initialized. The new division of labor is: During board_init() muxes are setup and gpios are requested. During subsystem init gpios are toggled. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-10-22imx: Add error checking to setup_i2c()Simon Glass
Since this function can fail, check its return value. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-10-21ARM: i.MX: provide declaration for board_spi_cs_gpioEric Nelson
Provide a public declaration of the board_spi_cs_gpio() callback for i.MX SPI chip selects to prevent the warning "Should it be static?" when compiling with "make C=1". Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-09compulab: eeprom: add default eeprom busNikita Kiryanov
Add default eeprom bus setting. This addresses the trimslice compile error that was introduced with the addition of this setting. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-09-17Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-09-09arm: mx6: cm_fx6: add sata supportNikita Kiryanov
Add support for SATA. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: use eepromNikita Kiryanov
Use Compulab eeprom module to obtain revision number, serial number, and mac address from the EEPROM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: add i2c supportNikita Kiryanov
Add support for all 3 I2C busses on Compulab CM-FX6 CoM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: add usb supportNikita Kiryanov
Add USB and USB OTG host support for Compulab CM-FX6 CoM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: add ethernet supportNikita Kiryanov
Add ethernet support for Compulab CM-FX6 CoM Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: add nand supportNikita Kiryanov
Add NAND support for Compulab CM-FX6 CoM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: add support for Compulab cm-fx6 CoMNikita Kiryanov
Add initial support for Compulab CM-FX6 CoM. Support includes MMC, SPI flash, and SPL with dynamic DRAM detection. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09compulab: eeprom: add support for defining eeprom i2c busNikita Kiryanov
Create CONFIG_SYS_I2C_EEPROM_BUS #define to tell the EEPROM module what I2C bus the EEPROM is located at. Make cl_eeprom_read() switch to that bus when reading EEPROM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Dmitry Lifshitz <lifshitz@compulab.co.il> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-08-30omap5: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP5 board select menu to omap5/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap5"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2014-08-25cm-t54: fix eMMC boot mode checkDmitry Lifshitz
Boot from eMMC boot partition corresponds to BOOT_DEVICE_MMC2 omap_bootmode, while BOOT_DEVICE_MMC2_2 corresponds to the user data partition boot. Fix mmc_get_env_part() boot mode check to use a correct value. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-08-25cm-t54: fix EEPROM read return value checkDmitry Lifshitz
Fix cl_eeprom_read_mac_addr() return value check. Fix long line codding style issue in board_init(). Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-06-11cm_t335: Fix the U-Boot binary outputSimon Glass
Correct the binary output so that image_binary_size is really at the end of the image. Signed-off-by: Simon Glass <sjg@chromium.org>
