path: root/board/compulab/cm_t54/cm_t54.c
2016-03-15omap-common: Rename set_muxconf_regs_essential to set_muxconf_regsPaul Kocialkowski
There is no distinction between essential and non-essential mux configuration, so it doesn't make sense to have an "essential" prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-07-27omap-common: Common boot code OMAP3 support and cleanupPaul Kocialkowski
This introduces OMAP3 support for the common omap boot code, as well as a major cleanup of the common omap boot code. First, the omap_boot_parameters structure becomes platform-specific, since its definition differs a bit across omap platforms. The offsets are removed as well since it is U-Boot's coding style to use structures for mapping such kind of data (in the sense that it is similar to registers). It is correct to assume that romcode structure encoding is the same as U-Boot, given the description of these structures in the TRMs. The original address provided by the bootrom is passed to the U-Boot binary instead of a duplicate of the structure stored in global data. This allows to have only the relevant (boot device and mode) information stored in global data. It is also expected that the address where the bootrom stores that information is not overridden by the U-Boot SPL or U-Boot. The save_omap_boot_params is expected to handle all special cases where the data provided by the bootrom cannot be used as-is, so that spl_boot_device and spl_boot_mode only return the data from global data. All of this is only relevant when the U-Boot SPL is used. In cases it is not, save_boot_params should fallback to its weak (or board-specific) definition. save_omap_boot_params should not be called in that context either. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29compulab: eeprom: allow reading mac address from multiple eepromsNikita Kiryanov
Implement the option to select the eeprom i2c bus when reading mac address. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Ledvich <ilya@compulab.co.il> Cc: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-11-06omap: hsmmc: assume cd gpio is active lowIgor Grinberg
Switch the default CD GPIO polarity to active low. The current hsmmc driver assumption that the CD GPIO is active high, but in the real hardware, usually the opposite holds. The usual SD card socket has a mechanical switch which is grounded as soon as a card is inserted. Of course there might be some board logic which inverts the signal, but as far as current users are concerned, there is no such logic. Current U-Boot users either not using the CD functionality, or have a different way (e.g. external to SoC GPIO controller) for checking the card presence. This patch also brings the polarity assumption in line with the Linux kernel and adds appropriate comments. This patch also might spare issues once the TWL GPIO driver will be converted to the DM. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Dmitry Lifshitz <lifshitz@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-08-25cm-t54: fix eMMC boot mode checkDmitry Lifshitz
Boot from eMMC boot partition corresponds to BOOT_DEVICE_MMC2 omap_bootmode, while BOOT_DEVICE_MMC2_2 corresponds to the user data partition boot. Fix mmc_get_env_part() boot mode check to use a correct value. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-08-25cm-t54: fix EEPROM read return value checkDmitry Lifshitz
Fix cl_eeprom_read_mac_addr() return value check. Fix long line codding style issue in board_init(). Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-05-23cm-t54: add environment partition runtime detectionDmitry Lifshitz
Add environment partition runtime detection callback. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-05-23cm-t54: add EEPROM support and MAC address handlingDmitry Lifshitz
cm-t54 Eth MAC address is stored in onboard EEPROM. Add EEPROM support and setup stored Eth MAC address. If EEPROM does not contain a valid MAC, then generate it from the processor ID code (reference code is taken from OMAP5 uEvm board file). Modify Device Tree blob MAC address field with retrieved data. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-05-23cm-t54: add cm-t54 board supportDmitry Lifshitz
Add cm-t54 board directory, config file. Enable build. Basic support includes: Serial console SD/MMC eMMC USB Ethernet Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
