path: root/board/compal
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-05-13ARM: tegra: move NVIDIA common files to arch/arm/mach-tegraMasahiro Yamada
All the Tegra boards borrow the files from board/nvidia/common/ directory, i.e., board/nvidia/common/* are not vendor-common files, but SoC-common files. Move NVIDIA common files to arch/arm/mach-tegra/ to clean up Makefiles. As arch/arm/mach-tegra/board.c already exists, this commit renames board/nvidia/common/board.c to arch/arm/mach-tegra/board2.c, expecting they will be consolidated as a second step. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: Tegra20 pinmux cleanupStephen Warren
This renames all the Tegra20 pinmux pins and functions so they have a prefix which matches the type name. The entries in tegra20_pingroups[] are all updated to remove the columns which are no longer used. All affected code is updated to match. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-11-01Makefile: convert makefiles to Kbuild style and delete grep switchMasahiro Yamada
We have converted all makefiles needed to build $(LIBS). Until this commit we used to grep switch so that U-Boot style and Kbuild style makefiles coexist. But we do not need any more. Goint forward, use always Kbuild style Makefile when adding a new Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-03-14Tegra: MMC: Add DT support to MMC driver for all T20 boardsTom Warren
tegra_mmc_init() now parses the DT info for bus width, WP/CD GPIOs, etc. Tested on Seaboard, fully functional. Tamonten boards (medcom-wide, plutux, and tec) use a different/new dtsi file w/common settings. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: Add/enhance sdhci (mmc) nodes for all T20 DT filesTom Warren
Linux dts files were used for those boards that didn't already have sdhci info populated. Tamonten has their own dtsi file with common sdhci nodes (sourced from Linux). Signed-off-by: Tom Warren <twarren@nvidia.com> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: Change /include/ to #include for C preprocessorTom Warren
dts Makefile has the arch & board include paths added to DTS_CPPFLAGS. This allows the use of '#include "xyz"' in the dts/dtsi file which helps the C preprocessor find common dtsi include files. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-01-17tegra: fdt: sort dts filesAllen Martin
Sort nodes in dts files according the the following rules: 1) Any nodes that already exist in any /include/d file, in the order they appear in the /include/d file. 2) Any nodes with a reg property, in order of their address. 3) Any nodes without a reg property, alphabetically by node name. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-17tegra: fdt: remove clocks nodesAllen Martin
These nodes are unused. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-16tegra: enable LCD on PAZ00Marc Dietrich
This adds LCD panel descriptions to the device tree of PAZ00 and enables LCD support in the configuration. Signed-off-by: Marc Dietrich <marvin24@gmx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19ARM: tegra: enable 8-bit SD slots in board filesStephen Warren
Harmony contains an SD slot with all 8 bits routed. This allows plugging in an eMMC-chip-in-SD-form-factor. Seaboard/Springbank/Ventana/AC100 all have an eMMC chip with all 8 bits hooked up. Now that the U-Boot eMMC code fully supports 8-bit operation, initialize those ports as 8-bit instead of 4-bit to improve performance. Whistler was already registering its ports as 8-bit. TrimSlice doesn't have any 8-bit ports. I don't have any Avionic Design boards nor the Colibri board to test with. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29tegra: move common features to a common makefileMarc Dietrich
For Non-Nvidia boards to include newly added features (like emc clock scaling) it would be necessary to add each feature to their own board Makefile. This is because currently the top Makefile automaticly includes these features only for Nvidia boards. This patch adds a simple Makefile include so all new features become available for non-Nvidia board vendors. Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Warren <twarren@nvidia.com> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Lucas Stach <dev@lynxeye.de> Signed-off-by: Marc Dietrich <marvin24@gmx.de> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra20: rework UART GPIO handlingLucas Stach
Rename board provided gpio_config_uart() to gpio_early_init_uart() as it does the same thing as the equally called function provided by the uart-switch code. This allows to simply call this function in early board init whether or not we are building with CONFIG_UART_SWITCH defined. Also provide a weak symbol for this function, to avoid the need to provide this function for boards that don't need any fixup. This patch supersedes the earlier posted "tegra: convert gpio_config_uart to weak symbol". Build tested with MAKEALL -s tegra20 Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15Tegra20: Move some include files to arch-tegra for sharing with Tegra30Tom Warren
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h. Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20' 'root' file. All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-01tegra20: make board mkdir commands unconditionalAllen Martin
Change the mkdir commands for the object directories to be unconditional. This fixes an issue when building for SPL where SRCTREE and OBJTREE are the same, but $(obj) is under SPLTREE. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: fix leftover CONFIG_TEGRA2_MMC & _SPI build switchesTom Warren
Missed some boards after my tegra2_mmc.* -> tegra_mmc.* change, and one instance of CONFIG_TEGRA2_SPI. MAKEALL -s tegra2 AOK, Seaboard MMC AOK. Didn't test Tamonten, Paz00 or TrimSlice, as I have none here. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2012-07-07tegra: paz00: add device tree supportStephen Warren
... to enable USB host support, which enables Ethernet support. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: sync SDIO1 pingroup enum name with TRMLucas Stach
Signed-off-by: Lucas Stach <dev@lynxeye.de> CC: Tom Warren <twarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: paz00: fix typo in SD slot CD detect GPIOStephen Warren
2012-02-12tegra2: Add support for Compal Paz00 (Toshiba AC100)Stephen Warren
The Toshiba AC100 (Compal code-name Paz00, aka Dynabook AZ) is a netbook derived from the NVIDIA Tegra Harmony reference board. It ships with Android, but is often repurposed to run Linux. This patch adds just enough support to get a U-Boot serial console, and the ability access built-in eMMC and the external SD slot. v2: * Rebased on latest HEAD, incorporated changes made to other board files. * Moved board files from board/nvidia to board/compal. * Switched to correct odmdata value. This required add the previous patch to fix U-Boot's interpretation of the odmdata RAM size field. * Removed nvmem= from default Linux kernel command-line; no drivers use the reserved memory yet, so there's no point reserving it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
