path: root/board/comelit
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2011-11-04ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPELuca Ceresoli
MACH_TYPE_OMAP3_CPS was dropped in the latest mach-types sync (47af6f61bcd9) because it is not mainlined in Linux. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Wolfgang Denk <wd@denx.de> CC: Tom Rini <tom.rini@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap: gpio: Adapt board files to use generic APISanjeev Premi
This patch contains updates the sources in the board files to use the generic API. Signed-off-by: Sanjeev Premi <premi@ti.com>
2011-09-04OMAP3: DIG297: Use generic MMC driverTom Rini
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc driver. This patch is based on the work done for Beagle, etc. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27ARMV7: OMAP3: Add support for Comelit DIG297 boardLuca Ceresoli
Board support for the DIG297 board manufactured by Comelit Group SpA. It is a custom board based on the BeagleBoard <http://beagleboard.org/> by Texas Instruments. The board support is based on the BeagleBoard implementation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
