path: root/board/cogent
2014-01-24board: delete unused header filesMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-11-15board: cogent: include header files in a more natural wayMasahiro Yamada
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-04-02replace last __bss_end__ occurrences with __bss_endAlbert ARIBAUD
Simon Glass' commit 3929fb0a141530551b3fce15ee08629f80d5ef2a, which changed all occurrences of __bss__end__ into __bss_end, left behind some untouched __bss_end__ occurrences in all 33 u-boot.lds.debug files, in board/mousse/u-boot.lds.ram and in board/mousse/u-boot.lds.rom. These are replaced here. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-17serial: Use default_serial_puts() in driversMarek Vasut
Replace the in-place ad-hoc implementation of serial_puts() within the drivers with default_serial_puts() call. This cuts down on the code duplication quite a bit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from serial driversMarek Vasut
Remove the support for not-CONFIG_SERIAL_MULTI part from serial port drivers and some board files. Since CONFIG_SERIAL_MULTI is now enabled by default, that part is a dead code. Remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: powerpc: Implement CONFIG_SERIAL_MULTI into cogent serial driverMarek Vasut
Implement support for CONFIG_SERIAL_MULTI into cogent serial driver. This driver was so far only usable directly, but this patch also adds support for the multi method. This allows using more than one serial driver alongside the cogent driver. Also, add a weak implementation of default_serial_console() returning this driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2011-11-07board/cogent/flash.c: Fix GCC 4.6 buiild warningWolfgang Denk
Fix: flash.c: In function 'flash_init': flash.c:295:16: warning: variable 'fip' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Murray Jensen <Murray.Jensen@csiro.au>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-278260: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-11-15Revert "Correct fixup relocation for mpc8260"Grant Likely
This reverts commit 5af61b2f4b838a05f79be274f3e5a66edd2d9c96. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Correct fixup relocation for mpc8260Grant Likely
2007-07-04Consolidate mpc8260 linker scriptsGrant Likely
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-08-12Fix Murray Jensen's mail address.Wolfgang Denk
Patch by Murray Jensen, 30 Jun 2005
