path: root/board/cobra5272
2006-05-09Fixes for gcc 3.4 based m68k toolchain,Marian Balakowicz
based on patch by Jate Sujjavanich.
2006-03-11More GCC 4.x code cleanupWolfgang Denk
2005-01-09Patch by Florian Schlote, 08 Sep 2004:wdenk
Add support for SenTec-COBRA5272-board (Coldfire).
