path: root/board/cmc_pu2
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-03-22cmc_pu2: fix implicit declaration of function 'eth_setenv_enetaddr'Jean-Christophe PLAGNIOL-VILLARD
2009-03-22cmc_pu2: fix misc_init_r prototypeJean-Christophe PLAGNIOL-VILLARD
2009-03-20cmc_pu2: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Also rename load_sernum_ethaddr() to misc_init_r() so we don't need to handle this board specially in common ARM code. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2007-08-14Update Makefiles for merged and split at45.c.Peter Pearse
2007-08-14Delete the merged files.Peter Pearse
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2005-10-05* Move dm9161.c and lxt972.c into cpu/arm920t/at91rm9200Wolfgang Denk
Patch by Anders Larsen, 29 Apr 2005 * Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005 (8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5)
2005-08-19Initialize serial# and ethaddr from manufacturer data in EEPROM on CMC-PU2Wolfgang Denk
Patch by Martin Krause, 08 Jun 2005
2005-08-19Add new board specific commands for TQM5200/STK52XXWolfgang Denk
- Sound commands (beep, wav, sound) - Test commands (led, can, backlight, rs232) Patch by Martin Krause, 02 May 2005
2005-08-19Add automatic HW detection for another CMC_PU2 variantWolfgang Denk
Patch by Martin Krause, 20 Apr 2005
2005-04-06Patch by Steven Scholz, 06 Apr 2005:wdenk
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200 - moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
2005-04-01Patch by Martin Krause, 01 Apr 2005:wdenk
Add automatic HW detection for CMC_PU2 and CMC_BASIC
2005-03-31Patch by Steven Scholz, 13 Dec 2004:wdenk
Remove duplicated code by merging memsetup.S files for at91rm9200 boards into one cpu/at91rm9200/lowlevel.S
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-12-20Fix problems with CMC_PU2 flash driver.LABEL_2004_12_20_1220wdenk
2004-12-19* Fix problems with CMC_PU2 flash driver.LABEL_2004_12_19_2240wdenk
* Adjust INKA 4x0 default settings
2004-12-14Cleanup for CMC_PU2 boardwdenk
2004-12-13Patch by Steven Scholz, 12 Dec 2004:wdenk
Fix typo in AT91 memory setup.
2004-12-10* Clean up CMC PU2 flash driverwdenk
* Update MAINTAINERS file * Fix bug in MPC823 LCD driver
2004-11-24* Fix udelay() on AT91RM9200 for delays < 1 ms.LABEL_2004_11_25_0035wdenk
* Enable long help on CMC PU2 board; fix reset issue; increase CPU speed from 179 to 207 MHz.
2004-11-21* Update for AT91RM9200DK and CMC_PU2 boards:wdenk
- Enable booting directly from flash - fix CMC_PU2 flash driver * Fix mkimage usage message
2004-10-10Code Cleanupwdenk
Patch by Gary Jennejohn, 04 Oct 2004: - fix I2C on at91rm9200 - add support for Ricoh RS5C372A RTC
2004-10-10* Patch by Gary Jennejohn, 01 Oct 2004:wdenk
- add support for CMC PU2 board - add support for I2C on at91rm9200 * Patch by Gary Jennejohn, 28 Sep 2004: fix baudrate handling on at91rm9200
